Results 1 to 8 of 8
Thread: Rear suspension noise(clunk)
    Vl Executive
    May 2008
    Default Rear suspension noise(clunk)
    Any ideas, my rear suspension clunks over rough surfaces. I replaced the panard bushes, no change.
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    How low is your car? What size wheels have you got on there? Any suspension mods besides the bush change?
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    check the shocker, lower and upper control arms bushes.
    it's probably the exhaust knocking the axle housing or the fuel tank,
    broken exhaust hangers/rubbers?
    aftermarket bolt on exhaust?
    Nobody wants to play with me
    vl commodore rb30e N/A
    Mar 2008
    sunshine coast
    it's probably your exhaust hiting the penhard rod. change your exhaust rubbers(middle and rear. they would be sagging from age),if that don't work then get the exhaust bent over the penhard rod more.
    jetspin_vn's Avatar
    jetspin_vn is offline JetSpin Racing Team
    VN GTS
    Nov 2003
    Mission Bay, Auckland, New Zealand
    Yep, do the zorst rubbers. My Panhard rod has made a nice big dent in the pipe since I lowered my car.
    JetSpin Racing Team Mantre:
    "F**k safety, I'm in a hurry"
    '04 Holden VY II SS
    Dec 2007
    i had a severe clunking in my VL, turned out to be the bushes in the upper diff control arms... apparently its a very common problem on VL's... the clunk mainly occured when accellerating (only when pedal was tapped or pushed) and when going over bumps... if it helps
    Quote Originally Posted by Urban Dictionary
    sheepy:
    Person that is deemed utterly useless most often due to a hangover and is in need of a "sheep" herder
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    i had a clunking in my VN and it turned out that the nut that holds onto the syspension at the top was loose so it moved up and down, clunking in the process.
    i know that it is a VL but food for thought.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    The two Rubbers either side above diff housing mate! (that's if you have lowered it...)
    Go over a bad section of road or whatever and the housing will hit the rubbers.
    Rip them out and hack saw them back so there is about 1 inch left of them.
    They are a mongrel to put back in, just use a flat head screwdriver and grease to wedge in and a few coldies. (unless you can cut them in there!)
    Only Negative thing with doing this is you will get more scraping on passenger rear tyre wall. You can solve this with a adjustable panhard rod.
    Positive thing is no more clunking as it bottoms out and giving the spring and shocks more travel therefore more of a comfy ride...
    I did this a few months ago and cant believe how much better it is.
  1. Clunk noise in rear end...
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2009, 05:37 PM
  2. Strange Clunk Noise
    By fullaaa in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-05-2008, 12:51 PM
  3. VY clunk from rear
    By younglion in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-02-2008, 07:26 AM
  4. clunk/noise in front left wheel of vs
    By vsplook in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2007, 04:41 PM
  5. Clunk noise from the back
    By scbh81 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-07-2005, 09:57 PM
