Results 1 to 6 of 6
Thread: drill/tapping S1 block, need to know ASAP!!!
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Default drill/tapping S1 block, need to know ASAP!!!
    .......need to know by tommorow.......the sump will be off
    ive searched though JC and CT and i cant find a straight awnser, just the crap of get a S2 block etc.
    i need to know how big do i drill and tap, how deep (ive heard no more then 3mm)
    and which ones, heres a few pics to point on
    PINK- has thread and looks like its been drilled as it goes all the way into the block
    GREEN- has thread but is blocked
    YELLOW- has thread but is blocked
    BLUE- not sure
    and what is each one used for, ie oil drain, oil feed etc
    inside the pink ring
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Oil feed/return and Water feed.
    I'll have a search for a pic. Oil return is actually that massive plug to the left on the bottom, looks like you have a plate over it.
    Oil feed is above that plate. that I mentioned above. Water feed I believe is blue. But I need to find the picture to confirm.
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    Quote Originally Posted by vnv8driver View Post
    what exactly are you drilling them for?
    So he can turbo charge the series 1 rb30. Series 2 rb30 motor had the holes tapped and plugged with bolts from factory.
    Oct 2005
    well ive got it figgered out now, with a little help from a mate and r31skylineclub, its sused
    PINK is oil feed
    bellow the pink is a flat area which is the oil drain. that needs drilling and tapping
    BLUE is water feed.
    water return is near the throttle
    good help over here with pics too
    Turbocharging - R31info
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Bax
    Nothing
    Jan 2004
    QLD
    Sorted. Yeah water return you just plug into one of the heater pipes. T-piece it in.
  1. vr tapping
    By krisjanik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2010, 08:04 AM
  2. Roll Pins and stuck drill bits
    By matty88 in forum General
    Last Post: 14-10-2006, 05:57 PM
  3. Tapping Noise
    By Bloka in forum General
    Last Post: 24-07-2006, 01:31 PM
  4. house robbed & took me car keys too. what is the drill?
    By metalskin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2006, 02:09 AM
  5. VN V6 tapping
    By potshots007 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2005, 01:56 PM
