have to replace seats in my VL,, was wondering if newer model seats will fit?
front seats at wreckers look as though they might(VN -VS)??
no idea 'bout the rears though??
please help as i want to go get some tomorrow if i can get info!!!!
you can get them to fit mate but they do need som modifying, the rails arent the same as far as i kno, i think you have to put the vl rails on or something, im sure its been covered on here or try calaisturbo.com
There's an excellent thread on s t r e e t c o m m o d o r e s . c o m :P
all about it. Look for a thread called "Vh Seats!"
thanks, still need more help
cant find that thing on vh seats
any more help be much appreciated
you have to take the seat off the vs rails and attach them to the vl rails a little bit of stuffn around but it's not hard to do even without instructions.
back seats need abit more modification.
Nobody wants to play with me
The fun part is getting the seats out of the VL if they have never been removed before.
why is that?
these have never been out before i think?
be any easier with vp seats front and rear instead of later ones?
still just swap the front rails?
still will have to swap the rails for front,
anything after the vl series is wider so the rears wont just fit in perfect,
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
hell yaeh.....6 stripped hex heads.....2.5 hours......alot of abuse....they finally come out... seat bolts are factory glued with that blue locktite and if they have never been removed you are going to have some fun...as far as fitting different seats use the vl rails and attach to new seats..you may have to make some brackets though as the location holes in the new seats may diifer from the vl seats.
if i can work out how to do it i will post some picks of mine which i am currently modifying with some mazda bucket seats..gimme 10 mins
HONESTLY OFFICER, IT WAS CONSECUTIVE U TURNS..
cant work it out..not too good with computersill work on it
thanks fella's
i will let ya know how i go tomorrow
are the doors hard to remove?
just bang ther pins out?
have to replace the 2 right side doors on weekend also
pillar looks fine
was the wood sticking out back of truck that poked into the rear door and got front door with a seperate stick
only doors
hopefully
lol
