Results 1 to 9 of 9
Thread: HELP !! cant remove v l door even with tool????
    vn v6 calais
    May 2008
    Angry HELP !! cant remove v l door even with tool????
    trying to take door pins out of vl using a door pin removal tool
    no luck still
    tempted to scrap it and go bak to a ford where the doors come of with bolts and a spanner
    why are these comoodores so difficult
    vl berlina wagon 6cyl
    Jul 2005
    tool may be the wrong size, you may need a nail, the pins are hollow so may seem to be not there
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Try the vice grip trick i told you in the other thread, if your not sure how to do it, ill take some pictures tonight if you like.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    vn v6 calais
    May 2008
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by Tom_1569 View Post
    use pointy vice grips, clamp on flared end and hit up or down (depends on which pin)
    can use multi grips
    makes sure the little cylinder nuts is the right size, think theres to sizes from memory. the one from my work was too big so we ordered in a smaller size and it worked
    soak it with crc, wd40 or rp7, leave over night to makes it penitrates well
    i had the same prob with one of the pins on my vls door, some nob from before used a bigger pin and hammered it in
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    No problems, ill do it tomoro, its ****ing down rain at the moment.
    vn v6 calais
    May 2008
    got the door done
    the wrecker i got the door from swaped them over for me for 20 bucks.
    he thinks the pin was to big, i bought new pins and got him to use them when putting door back on,.
    was happy to see it was hard for him also, thought was something i was doing wrong,lol
    all done now, thank f@#k
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Good to hear you got it done and 20 bux isnt to bad.
    I tryed to get the photo for you but realised VK ones are different, VL door pins are the same as Vn correct? As thats what i though, but if they are the same a VK then my method doesnt work.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    The pins from the VB through to the VL are the same. Sometimes the pins are damaged at the factory when they are installed if the hinge on the door is not aligned with the hinge part on the pillar Worked at G.M.H for a number of years and bent my share ( sorry if one of them was yours ha ha ) .The pins are made of spring steel and have a groove down the middle . Most pin removal tools are a waste of money . Best to use a drill or bolt of a smaller diameter and belt them out with a hammer . The top pin is removed down through the hinge and the bottom one is removed by hitting it up through the hinge .Another reason that makes them hard to remove is that after the pins are fitted to the door ,the door is then adjusted to suit the car which involves bending the hinge which inturn jams the pin in the hinge.
  1. door hinge removal tool and pins
    By kowan in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-10-2007, 12:57 PM
  2. how to remove door vents?
    By gottavecalaisv in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-03-2007, 09:21 PM
  3. Remove door skirts (VT)
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2006, 11:26 PM
  4. how to u remove a door of a vn
    By VNCommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2006, 08:29 PM
  5. how to remove door from car?
    By Brenno85au in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-08-2005, 01:53 PM
