Results 1 to 15 of 15
Thread: do later model front calipers fit?
    starfire vc's Avatar
    starfire vc is offline now on 10 pound
    VL turbo, RB30ET VH wagon, 64 EH in the build.
    May 2007
    Brisbane,North
    Default do later model front calipers fit?
    just wondering if later model front calipers fit on a vl without an adaptor. i was thinkin like vr vs units???
    the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    vs onwards no
    not positive about vr
    if you want a upgrade besides the vt twin spot then vl turbo or v8 is what you want, they are the same as vn v8 too
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    May 2007
    Brisbane,North
    ok cheers mate
    was just wondering if i cud use the vented ones on the likes of a vn ,vp etc. i assume there just single piston units with cooling fins being the only majour diffrence?
    i will be doin the vt brake upgrade later on down the track along with the vt booster.but was wondering wat else i could do in the mean time
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    vs should bolt on. anything single piston from vn-vs should no worries. just make sure you go the 290mm rotors to suit.
    and dont pay huge prices for "vl turbo" calipers, theyre not worth it. when you can get say vr calipers for $40ish and bolt them on(did this on my vn)
    Oct 2005
    Quote Originally Posted by hakhawk View Post
    vs disc are free floating, not bolted on the hub like vl/vn disc
    thats why i didnt specify the vr as im not sure if the float or bolt
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    hakhawk's Avatar
    Jan 2005
    hakhawk's Avatar
    Jan 2005
    vr has the same disc setup as vs.
    vb-p have the hub incorporated into the disc and bolt onto the spindle
    vr onwards are a hat style which slides onto a seperate hub which bolts to the spindle.
    both setups work the same way, and calipers fit earlier models with the right disc.
    Oct 2005
    my bad thought you were refering to disc, didnt read properly
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    May 2007
    Brisbane,North
    thanks for your comments.ive gone for a set of sloted turbo rotors and a set of new turbo calipers to suit,the cailipers brand new were only bout 100 each and included brake pads. heres wat they look like
    Attached Thumbnails Attached Thumbnails do later model front calipers fit?-image052.jpg
    hakhawk's Avatar
    Jan 2005
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Wink
    what part number rotor is that? looks a bit too small
    I'll 2nd that too!:my:
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    May 2007
    Brisbane,North
    u gota keen eye mate. thats actually a pic of a standard rotor.here's a pic with the correct rotor
    Attached Thumbnails Attached Thumbnails do later model front calipers fit?-p1010066.jpg
    hakhawk's Avatar
    Jan 2005
    heh, thats better. i got the same setup on the vn, and i look at it through the wheel spokes every day i go out to the car
    '04 Holden VY II SS
    Dec 2007
    where did you get your rotors and calipers from?
    Quote Originally Posted by Urban Dictionary
    sheepy:
    Person that is deemed utterly useless most often due to a hangover and is in need of a "sheep" herder
  15. #15
    May 2007
    Brisbane,North
    Quote Originally Posted by sheepz89 View Post
    repco mate ,just know the right ppl there...
  1. Installing a Vy model strut bar on a earlier model Commodore
    By VXWAGMAN in forum Holden Commodore How-To's
    Last Post: 20-09-2009, 03:28 PM
  2. Will VR front calipers fit on my VN?
    By alexp36 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2008, 09:54 PM
  3. Wanted pair of VT - VY front brake calipers.
    By cruzn in forum Swap / Wanted to Buy / Trade
    Last Post: 26-02-2008, 06:42 AM
  4. FS: VH/VK rebuilt front calipers - new paint + overhaul kit (SA)
    By DANNY8 in forum Parts And Other Items For Sale
    Last Post: 18-09-2007, 01:10 AM
  5. F/S ( Melb ) - NEW VT twin psiton calipers/rotors suit early model commodores
    By GTS1963 in forum Parts And Other Items For Sale
    Last Post: 03-01-2006, 12:48 AM
