Results 1 to 6 of 6
Thread: Holden 304 stroked to 383 into VL
    '04 Holden VY II SS
    Dec 2007
    Default Holden 304 stroked to 383 into VL
    Hey guys,
    Looking at starting a new project and wondering if anyone has done this before and has some hints or tips for doing it... here's my story...
    I have a '87 VL Berlina with a RB30E, looking at putting a Holden 304 (EFI 5L) stroked to 383ci into my VL. ALL engine work will be done before it goes into the engine.
    Here are my questions:
    1. Has anyone put a 304 into a VL?
    2. What are some of the main problems encountered when putting a 304 into a VL? I would say there is a problem with the steering rack, crossmembers, cooling system etc. but if you could give me some more input it would be most appreciated
    3. Would a 383ci pass engineering in a VL? If not, what would need to be upgraded? (Obviously brakes and suspension, but what else?)
    Any and all information would be gratefully appreciated, i'm not looking at starting until i have all the parts sourced and all the information i need to start the project.
    Thanks, sheepz89
    Quote Originally Posted by Urban Dictionary
    sheepy:
    Person that is deemed utterly useless most often due to a hangover and is in need of a "sheep" herder
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    You will need V8 k-frame from a Vl, and the 304 should pretty much bolt up.
    A 383 stroker will most likely not pass any EPA bull crap though, although it would be MINT.
    And yes its been done plenty of times before.
    You will also need loom and computer out of donor car.
    Not sure about problems with steering rack and what not, but i would say it would be fine, dont VN's share the same setup pretty much, and the 304 is in a vn....
    '04 Holden VY II SS
    Dec 2007
    has anyone on here put a 304 into a VL?
    sheepy:
    Aug 2005
    Mt Martha, Vic
    VL EXEC
    Apr 2008
    im doing a 308 atm, just change the frame as already said, with your steering, is your vl power seering or not? mine wasnt, but when i got the sub frame and stuuf it had a power steering set up on it, so i had to change the steering collum as it was too long by about an inch...
    HONESTLY OFFICER, IT WAS CONSECUTIVE U TURNS..
    '85 HDT VK SS, '03 Liberty GT, '06 Forester XT
    Jun 2006
    Quote Originally Posted by Wagon_Wheel View Post
    And yes its been done plenty of times before.....
    a 383 can be made ADR compliant plus they can't tell visually it's a stroker as its the same block etc etc
    as said though, loom, V8 k frame, engine mounts, tail shaft, gearbox, suspension parts ( springs, shocks to cope with extra weight ), cooling system, steering and.... brakes
  1. Stroked and Blown VT
    By MaN|aC in forum VT - VX - VU - WH - V2
    Last Post: 29-06-2009, 08:38 PM
  2. stroked 5ltr
    By xcop5l in forum V8 Development and Modification
    Last Post: 27-09-2006, 08:27 PM
  3. stroked and charged vs ss
    By helay39 in forum General
    Last Post: 29-03-2006, 04:01 PM
  4. stroked vp
    By stockvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2006, 09:32 AM
