Results 1 to 10 of 10
Thread: Best diff??
    '04 Holden VY II SS
    Dec 2007
    Default Best diff??
    Just wondering if anyone knows what the best diff to use in a VL is?? I've heard nothing but good things about the VL Turbo/V8 diffs, but wondering if later model LSD's will fit into a VL with little to no modification? Cheers.
    Quote Originally Posted by Urban Dictionary
    sheepy:
    Person that is deemed utterly useless most often due to a hangover and is in need of a "sheep" herder
    Jun 2005
    later model LSDs are 28 spline. your VL is probably 25 spline
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    immortality's Avatar
    immortality is online now crappy ol' VN driver
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Body by Holden, Soul by Brock
    the Legend will live forever
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by sheepz89 View Post
    VN-VS ran the same Borg Warner M78 diff as the VL V8 and VL turbo, except they were slightly wider.
    So a VL V8 diff or VL turbo diff will be perfect. 28 spline, 4 pinion diff. V8's had a 3.08 ratio whilst the 6's had a 3.45 ratio.
    The n/a VL 6 had a 25 spline, 2 pinion version of the diff.
    '04 Holden VY II SS
    Dec 2007
    Ok cool cheers guys... im looking at putting a 383 stroker into it and just seeing what my alternatives are... i currently have the standard VL n/a diff with drums on the back so i need to upgrade the whole piece anyway... thanks for your replies
    sheepy:
    1991_Vn2nV's Avatar
    Mar 2006
    98 VT Acclaim
    Aug 2008
    New Zealand
    are the v8 vl diffs and vl turbo diffs limited slip or locked? if not, what makes them different (or better) than the standard N/A vl diffs?
    '87 VL Calais with L67
    Aug 2007
    Quote Originally Posted by madrx3boy View Post
    stronger differential spider (twice as many carrier gears)and heavy duty halfshafts. (more splines, due to wider diameter.)
    This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
    1991_Vn2nV's Avatar
    Mar 2006
    Adding to the previous post...
    LSD was only an option (on the V8's atleast) but a rather common option. Some are just single spinners.
    As stated in this thread, the V8/Turbo diffs are 4 pinion 28 spline. N/A diffs are 25 spline, 2 pinion.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    also the turbo and v8 diff gears are shot peened in borgies for a little extra strength,
    the 28 spline 4 pinion version as used in vl turbo and and v8 and from vn onwards was optionable with lsd.
    ========My Statesman 20's Mafless and 3.9's========
  1. V8 Diff vs 6cyl Diff
    By RSO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 09:45 PM
  2. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  3. Swap VZ diff for VE diff?
    By georgehifi in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-03-2008, 06:31 PM
  4. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
  5. Diff oil
    By DJL554 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-12-2006, 10:55 PM
