Results 1 to 11 of 11
Thread: Difference between S2 and S1
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Default Difference between S2 and S1
    I dont have a clue if my calais is a s2 or and s1. anyway to tell? the plastic on the top of the back seat is faded in most areas cept around to vaguel headrest shaped parts so im thinking it once had the rear headrest which were s2.
    this is only circumstantial tho, any proper way to tell?
    its a 1987 build if that helps?
    HOLDEN4life's Avatar
    HOLDEN4life is offline Power of The CALAIS
    Vl Calais
    Jan 2007
    liverpool (western suburbs sydney)
    is it a calais?? if so these are the differences between the two (they both had rear headrests)
    this is wat s2 has diff
    Interor:
    padded glove box
    solid headrest
    seat rails are able to be unbolted
    velour had a better design
    dash cluster was black (every other model had the blue square lines)
    Buttons were put on seats
    vents for the heater were colour coded to the dash
    centre console was velour where s1 was leather type
    Engine:
    was built ready for a turbo
    the belt for the alternator was smaller (first of some s2 had the s1 belts but from i think march 1987 they changed to the smaller ones)
    power steering pipe was run differant and gave better responce
    Pwr steering pump same brand just made diff
    Alternater (most fitted with bosch but some had hitachi wasnt just for the calais model)
    some models vary cause these whernt added over night was over a few months
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    well, i seem to have a s2 cluster (its black with grey dots) i think. glove box is standard, vents are black..
    I think overall its a s1 with a s2 cluster?
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Series 1 seats have low rectangle headrest, series 2 have higher square(er) ones.
    Pretty sure that goes for all levels across the range.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    There is no series 1 and series 2 VL. "updated" parts were fitted at any given time of production.
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by VL_5SPEED View Post
    Obviously, its just easier than referring to them as 'early' and 'late' models.....
    cheers sexy
    Aug 2007
    Newcasstle
    This is what I can think of atm
    *Door trims on the newer calais are different to the older calais
    * Berlina seats are slightly different
    *Dash boards on the newer calais are different
    *Some had the "CALAIS" badge above the stereo
    Thats all I can think of atm.
    Vl Calais
    Jan 2007
    thats true but about 98% of the population tell the differnce between the "S1 and S2" by the interior its probley the easiest way to tell the diff between the later and earlier.
    but as i stated earlier thats all the changes they mad between the Calais range. if i missed any please tell us as that has been extensive research by a bunch of members on another forum
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    wow i didnt know that. ok, cool. Thanks guys
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by HOLDEN4life View Post
    The headrest change was across all luxury levels, so the rectangle ones for all early models, and square ones for later models.
    cheers sexy
    vl berlina wagon 6cyl
    Jul 2005
    the non turbo engines had the turbo water connection at the rear of the block, LH side for S2 only, my wagon is S`1 with a S2 block, the previous owner had no interest in lifting the bonnet, the radiator catch tank got a leak and he really did overcook the engine so an exchange engine was needed
    it seems there were no identifing number changes between s1 and s2, Ive never heard any S2 starting numbers
  1. what's the difference with VZ SS and VZ SSZ??
    By miniac_beater in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-01-2008, 06:57 PM
  2. age difference
    By Garth in forum The Pub
    Last Post: 22-03-2007, 07:42 PM
  3. Difference
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2006, 09:32 PM
  4. The Difference
    By xstatic in forum General
    Last Post: 02-12-2003, 06:09 PM
