Have a crank from a 5L VL Calais ex police car. Needs a grind but otherwise is good.
are the VL 5L ones diferent to the older 5L's. is there anything special if its a police one?
cheers
jason
I believe that the VK-era 308/304 engines may have had better (large-valve) heads and different cranks than the stock 5l V8s of the time, but I don't think the VLs were different than all VL V8 Commodores.
There will be resources on the internet that explain the differences, just try a Google search for VL BT1 perhaps.
Cheers,
Macca
Senator 300 - the CLASSY C4B!
LS1 - ETP215 @ 62cc, Comp 215/223 .602/.609 @111+3, 8.050" P/R, Morel link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster timing chain, OTRCAI, T-56 - RipShift, 3.91:1 rear, DiFilippo 1.75" 4-1s St/St HPC coated, DiFilippo twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune. 308RWKW. My ride:-http://www.cardomain.com/ride/389253...lden-commodore
Not sure if the cranks are much different but the VL's ran the A9L engine which is pretty much a copy of the earlier L34, better/stronger than the normal early 308s, it would be the second best 304/8 to start with behind the injected motor
Did'nt know the police ever ran calais VLs ???
The A9L was unique to VL Group A Brock as far as iam aware.
ah stuffed if i know.
I got a crank with a heap of holden parts from a old holden dealership i cleaned out. it has a tag on it saying neeeds grind and that it came from a 5L VL Calais Police....
i dont even know! happy to sell you a car to go with your crank though!
Police 8's were stock standard straight off the production line.
so a "police crank" is no diferent to any other standard v8 vl crank?
no police crank its all bull**** mate they would be all the same
