Results 1 to 10 of 10
Thread: Sedan springs in a wagon?
    TWOJZ is offline Banned
    VL shagon ;)
    Apr 2008
    Adelaide!
    Default Sedan springs in a wagon?
    according to "Greg" the sedan has 14mm higher rear springs than the wagon (uncompressed)
    so, can I use lowered sedan kingsprings in the wagon, which would apparently lower the sedan around 30mm or so.
    I'm dont care if the car is lowered or not, I just want stiffer springs!
    I assume the kingspring "sports" are stiffer than standard?
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    they should be stiffer than the old stock ones, but the extra weight of a wagon usually makes for a softer ride again.
    ive got vn sedan springs in my vn wagon, and they fit fine.
    unless the old ones are ridiculously stuffed, id just get wagon springs to begin with.
    VL shagon ;)
    Apr 2008
    Adelaide!
    Quote Originally Posted by hakhawk View Post
    well, supercheap have a pair of rear sedan springs for $135, its not that cheap, but its convenient haha
    i dont want the wagon too low, as I often carry stuff, but I want it stiffer.
    currently, one side is sitting 15mm higher than the other! I dunno whats going on there! haha
    hakhawk's Avatar
    Jan 2005
    might be missing a rubber spring pad, or ones chewed out.
    you can buy standard height king springs aswell. we sell them retail about $160 a pair from memory(autobarn). just get supercheap to order some in and match the price. should only take a day or 2 to get in.
    carrying stuff with sedan springs, will make it sag easier aswell, which means lower when full.
    VL shagon ;)
    Apr 2008
    Adelaide!
    I dont think it is a worn/missing rubber, I think it may have a sedan spring in one side, and a wagon in the other haha
    how high is standard height though? anyone got pics? My wagon has never sat at standard height, haha.
    anyone got any second hand springs for sale?
    starfire vc's Avatar
    starfire vc is offline now on 10 pound
    VL turbo, RB30ET VH wagon, 64 EH in the build.
    May 2007
    Brisbane,North
    hey mate
    i put my old standard vl sedan springs in the rear of the wagon on the weekend..spring i took out were solid as..and sat really high..
    the sedan springs(with no insulator's installed) lowered it about 2 inches and gave a heap softer ride..still aint low enuff tho..so i might take a coil or two out..
    the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by TWOJZ View Post
    That doesn't sound right as wagons are heavier than sedans.
    I used Lovells seadn lowered sprigs in my VS wagon and they were the same height unsprung as the Kings SSL's I removed because they were just too low for my driveway.
    The seadn springs have 1 and 1/2 less coils than the kings ultra lows and the final height is about half way between Kings super low and ultra lows.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VL shagon ;)
    Apr 2008
    Adelaide!
    the sedan springs are higher uncompresed because they are softer. I'm going to order some proper springs anyway
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    just out of interest here are the springs from the wagon I have.
    364mm high, 9 complete coils, top coil width 10mm, bottom 13mm, coil diameter 94mm. see pics for part no.
    Attached Thumbnails Attached Thumbnails Sedan springs in a wagon?-364mm.jpg   Sedan springs in a wagon?-p235.jpg   Sedan springs in a wagon?-part-no..jpg
    Nobody wants to play with me
    VL shagon ;)
    Apr 2008
    Adelaide!
    Quote Originally Posted by jatsvl View Post
    thanks for that.
    I'm quite sure my standard springs are standard, even though kingsprings is trying to tell me otherwise, seeing as their springs are softer than standard
    I'll see what they say, I've told them, that I've had it confirmed that my original springs are in fact standard.
  1. Are sedan and wagon rear springs the same?
    By Kiwicommodore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2006, 12:52 PM
  2. sedan springs in a wagon
    By slappa. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 08:57 AM
  3. vs rear wagon springs into vs sedan
    By BOGANV8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2006, 07:27 PM
  4. Do VT/VX rear sedan springs fit a VT Wagon?
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-07-2006, 09:09 PM
  5. Wagon and Sedan Springs...
    By raZel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2005, 10:10 PM
