Results 1 to 4 of 4
Thread: what is the wattage high beam
    vn v6 calais
    May 2008
    Lightbulb what is the wattage high beam
    the h3 high beam globes could any one tell me what is standard for them
    also if anyone uses brighter ones what experiences have been had, good and bad.
    pretty keen to get brighter ones maybe.
    also the h4 globes with higher wattage, is it necesary to increase these as well or just the highbeam h3's?
    any information be much appreciated
    chhers
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    stock usually 60w for the H3 and 55/60w on the H4's. i generally wire in relays along with some 6mm wire and step up to 100w H3 and 90/100w H4
    vn v6 calais
    May 2008
    could ya explain in little more detail how to wre relays
    never done them b4
    VL Wagon
    Jul 2006
    Hamilton, New Zealand
    i found that no matter how high I went with the bulbs, the silver coating behind the bulb was not shiny enough to get out a decent amount of light, too much oxidation. oh h3 is standard 55w. there are bulbs out there that are the same wattage (so similar power consumption and heat) but give out more light, philips do a range and so do narva and hella I think
    Boredoms not a burden anyone should bear...
  1. high beam on and off
    By abehrendorff in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2006, 06:05 PM
  2. High Beam lights glowing when on low beam ?
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 03-09-2005, 10:15 AM
  3. high beam....
    By stock_vl in forum Electrical Wiring / Questions
    Last Post: 12-05-2005, 11:03 PM
  4. VT High Beam
    By budge in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2005, 04:39 PM
  5. no low/high beam
    By gambit120 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-11-2004, 02:06 PM
