Results 1 to 10 of 10
Thread: new bushes in alternator ???
    vn v6 calais
    May 2008
    Unhappy new bushes in alternator ???
    could someone please tell me how to put new bushes in 6cyl vl alternator?
    and also where do i get them from?
    will this fix alternator that is not working?
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    there is a module on the back of the alternator that has two screws on it, unscrew it and wriggle it out, if the old bushes are gone then thats your likely cause. if they arent worn ya alternator is finished
    vn v6 calais
    May 2008
    cheers mate
    where would i get new bushes?
    i am in melbourne
    would bursons, repco or something like that sell 'em?
    Set of thongs
    Dec 2005
    Stonedville
    yer they would they are about 50 to 70 dollars, check on ebay too u might save sum mulla. bosch is the brand i think
    vl berlina wagon 6cyl
    Jul 2005
    you might be better with a reconditioned exchange alternator with a decent guarantee
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    Change the whole regulator that contains the bushes is the easiest option. Its the matchbox sized black plastic box type thing held on by two screws on the rear of the alternator, undo screws, disconnect the wire, refit the new one & thats it. Fairly easy job to do!! (Easier than soldering in new bushes anyways IMO)
    Should be no more than $50 from any spare parts place. (Note there are 2 kinds of alternators fitted to VL's from memory, make sure you know which it is!)
    vn v6 calais
    May 2008
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    theres hitashi and bocsh.
    ive got mine appart a much i could so i can paint the casing,
    i was going to buy a recondition one (hitashi) but they wanted $490 as its apparently not the most easyiest to get and thats swap over
    bocsh is cheaper but im not sure by how much
    only diffrence is you will have to change your belt as one is 50mm longer
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    PRH
    PRH is offline
    vp s utility,and a KENWORTH
    Apr 2007
    Mildura Victoria
    if its a hitachi alt confine it to the deep coz they are just too expensive to repair,also bear in mind there are a lot morer dramas to an alt than brushes,in other words ya might spend ya cash on a reg assy only to find out that aint the prob,in other words take it to an auto elec.
    Regards Phillip
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    wreckers supply alternaters for $30-$50 second hand I know, but how often do you have to change them and if you don"t like what they are offering go somewhere else, had my vl five years and never done an alternater!
    Nobody wants to play with me
  1. Caster bar bushes and rear cross member bushes
    By Galixia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2008, 08:32 PM
  2. bushes
    By Matty o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2008, 08:47 PM
  3. bushes cost?
    By mpj_1982 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2007, 07:40 PM
  4. Z-Arm bushes
    By VN_Luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2006, 01:11 PM
  5. Z bar bushes or Radius Rod bushes?
    By Shounak in forum General
    Last Post: 12-04-2006, 05:29 PM
