when i bleed the radiator with the 2 bleeder bolts
so i remove both bolts then when water comes out the top one put bolt bak in that one?
then when water comes out of the lower one reinstall that bolt?
do it while car is running?
or when it is cold and turned of
or when it reaches operating temperature turn it of and do it then?
Here's a few images to help out.
There's information on each image that may be of use.
http://forums.justcommodores.com.au/...php?albumid=96
don't forget to have your heater on ( to circulate coolant through your heater core and remove any air pockets in there) and the car at operating temperature if the top hose is warm the thermostat is open then the coolant is circulating.
Nobody wants to play with me
cheers, thanks everyone
