Results 1 to 4 of 4
Thread: Rust in tail gate?
    TWOJZ is offline Banned
    VL shagon ;)
    Apr 2008
    Adelaide!
    Default Rust in tail gate?
    is it worth fixing to some extent?
    there is rust along the bottom edge of the rear window, its rusted right through in a few small spots, so some water gets into the tail gate, and drains out the bottom, however, you can't get to the rust from inside the car, as the bottom window ledge is there (I think)
    so, how could/should I fix it? not too worried about how it looks, I was just going to rust convert it, and silicon it from the inside, but you can't get silicon in there!
    thanks!
    VL shagon ;)
    Apr 2008
    Adelaide!
    that didn't get many responses
    haha
    I'm considering removing the window, and fixing it properly.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    best way is to just do it properly, cut it out. longer you leave it the worse it will become
    silcone will cause rust in metal so doing this as a quick fix will only make bigger problems later,
    if its fine and you aint botherd about it draining out the bottom just leave it till you can afford or are able to do it properly
    after cutting my rust out, that big area was caused by silicone trying to seal a leak
    rust free now
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VL shagon ;)
    Apr 2008
    Adelaide!
    neutral cure silicon won't cause it to rust.
    and if you applied rust converter first, it should also stop the "normal" silicon from making it rust too.
    the thing is... holden, in their infinite stupidity, made it so if water gets into the tail gate, it drains INTO the car! the drainage holes are on the inside of the tail gate, with little channels in the tail gate to direct water into them, and into the cabin of the car!
    I know the holden "engineers" aren't too bright, but that just takes the cake!
  1. FS: NEW Garrett GT35/40 External Gate ball bearing
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 23-04-2008, 05:00 PM
  2. VT II Acclaim wagon door and tail gate "creaks" when going over bumps.
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2006, 11:11 AM
  3. White VS SII Ute Tail-Gate.
    By Full Spectrum in forum Swap / Wanted to Buy / Trade
    Last Post: 17-05-2006, 10:23 PM
  4. VT - Body kit on tail gate
    By R-ON in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2005, 09:00 PM
