Results 1 to 4 of 4
Thread: how to replace a vl commodore altenator belt
    vl limited editon 2
    Jul 2008
    Default how to replace a vl commodore altenator belt
    hi guys does anyone know how to replace this belt properly as the only way i seem to be able to do it is with a screw driver and basically jimmying it on. who knows how to do it the right way?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    on the top side of the alternator there should be a bolt that goes though a bracket,
    undo it and it will pivot the alternator so you can fit/remove the belt
    if still to tight just crack the other bolt which holds the alternator on, this requires a spanner on each end
    pink circle is the bracket
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    as above and make sure you have the right replacement belt!
    Nobody wants to play with me
    Oct 2005
    S1 is a hatashi alternator
    S2 is a bosch alternator and they require a belt which is 50mm longer
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  1. replace fan belt
    By creamy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2008, 10:31 AM
  2. when to replace serp belt
    By muney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2007, 05:21 PM
  3. How to replace VN dive belt tensioner unit?
    By goldvn05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-05-2006, 07:03 PM
  4. Help! Battery/Altenator ??
    By sheldo86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2005, 08:27 PM
  5. how do you replace the horn in a VX SS commodore ?
    By chrisb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2004, 02:29 PM
