Results 1 to 17 of 17
Thread: VL idles OK, hunts above that.
    Jan 2005
    Default VL idles OK, hunts above that.
    Hi team,
    on behalf of the guy next door....
    His wife stopped the VL 6cyl auto wagon to fuel it up, after that it started and idled fine, but hunts above idle. At full throttle (1200 rpm maybe) it sounds like its being cut off by a rev limiter. If you open the throttle and try to drive it, it pigroots and lumps.
    I've just been over and checked the codes on the ECU, nothing shows up as strange there.
    I also clamped off the fuel return line to see if it would boost fuel pressure, that also had no affect.
    Weve got multimeter and a workshop manual, can someone here point us to a logical starting point please.
    Thankyou.
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    could be a mixture of things, without seeing it the list would start at-
    fuel pump
    airflow meter
    pressure regulator
    There the first ones to come to mind
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    from my understanding you need fuel air and spark to work
    if it wont rev over 1200rpm you starving the engine of either fuel or air and causing a limp mode
    turn ignition on and walk to the fuel flap area.
    can you hear the fuel pump humming as it primes??
    the pump should produce a humm or buzzing noise if its working even when the engines running.
    if no sound then there fuel pump has died
    i recall some thing about the catlic convertor collapsing which causes problems but im not sure if it would cause those exact probs, ill find out
    Quote Originally Posted by bangers View Post
    check for spark. if there is no spark at all from the coil lead THEN it will be either the CAS or the coil. If you have spark then it will probably be the CAT (catalytic convertor). When the CAT is stuffed the mesh in side deteriorates and blocks the exhaust allowing the car to only go 20km/hr if you're lucky, even not go at all.
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Jul 2008
    cat converters will usually stop a motor from running period in my experience with them, but i suppose anythings possible, restriction to the exhaust will prevent it from running/running properly. If that is the problem it wont last long until its stopped completely. remove and inspect it to make sure but by the sounds of things most likely a fuel/electrical issue
    BUT50 is offline BUT50
    VX Executive S2-VN SS
    Mar 2007
    Jan 2005
    Thanks for the rapid responses guys,
    tested fuel pressure and checked all vacuum lines for leaks again, and fuel regulator doesnt have fuel in vac lines,
    Looks like a CAS at this stage, he did put a 2nd hand dizzy in a few months ago Ive found out.
    Will let you know the outcome, cant get a CAS till monday here.
    Thanks again.
    vl berlina wagon 6cyl
    Jul 2005
    if its the airflow meter, removing the plug from it will make no difference
    Doctor Bob's Avatar
    May 2004
    Quote Originally Posted by Outwest34au View Post
    Thanks again.
    its the air flow meter, dont mess with the distributor
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Holdfast is offline Donating Member
    VE & VL
    Jan 2005
    Thanks again.
    Mate don't forget that the second hand dizzy may have a stuffed bearing.
    If the bearing is buggered it may put rust dust on the Crank Angle Sensor and the steel Rotor plate that has the slots cut in it.
    You may not have to replace the CAS but maybe cleanup the CAS and rotor.
    The bearing for the dizzy only costs about $7.
    Best of luck
    Jan 2005
    Latest update...,
    we put a new CAS and bearing in the dizzy, figured that wasn't going to be lost money after all the 2nd hand ones he has fitted. That never fixed the problem.
    We borrowed an airbox lid and bingo, problem solved instantly.
    So, I can go ebay-ing, but I thought I'd see if anyone here has a good 2nd hand or surplus new AFM they would like to convert to cash.
    Thanks again for the help.
    maxpower QLD's Avatar
    maxpower QLD is offline has mild super powers
    Xtrail/5spd VL
    Feb 2008
    QLD (the police state)
    I had a similer problem with my AFM so i decided to test it (you'l need a multimeter to do this) before going out and buying a new one and found that the screw had been adjusted too high . To test and adjust mine i removed the ruber boot off the plug on the AFM turned ignition on and inserted one probe on number 6(the wires are numbered on the AFM) and the other on number 1 , then i adjusted the screw til the multimeter was reading 3.55 volts or 382 Ohms . Your AFM might be beyond repair or what ever but its worth a try . I did it to mine and i was amazed how much of an improvement it's made to the car lol it revs so smoothly and pulls harder through gears (now my CAS is about to pack it in) but as i said it prob won't make a difference to ur AFM but its worth a try and may save u $150 bucks or so . Anyways thats my 2c
    Quote Originally Posted by VS Omega View Post
    "gonna beat you to the next set of lightes uleh"
  15. #15
    Jan 2005
    Thanks Maxpower, as a stopgap measure I thought I might adjust it while we waited for the new one, It read 402 Ohms. When it was adjusted to 382 made no difference what so ever.
    Thanks for the help from all the interested forum members.
    Chalk this one up as 'case closed'
    Cheers :-)
  16. #16
    eko's Avatar
    eko
    eko is offline 3kO
    Soon to own vb commy end of year
    Aug 2007
    South Eastern Suburbs
  17. #17
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Was it the CAS (crank angle sensor eko) or the AFM?
    I would have said CAS because the AFM only deals with the mixture under 1200 and then the cas takes over.
  1. VS Idles to fast when cold, what are IAC & MAF
    By dpayne in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2009, 06:06 PM
  2. VN idles rough won't Rev
    By aries75au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2008, 06:53 PM
  3. idles up and down
    By jayignorantz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2006, 12:28 AM
  4. Door Rattle - Yes the Rattle that hunts Holdens
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2006, 09:01 PM
  5. Vn V8 Idles High
    By NZVNSS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2005, 06:28 AM
