Results 1 to 5 of 5
Thread: annoying banging problem rear suspion area
    vn v6 calais
    May 2008
    Angry annoying banging problem rear suspion area
    car is making bang noise from rear of car when i hit a big enough divit in the road,,, i reckon it may be panhard rod bushes, how to tell f panhard rod bushes are knackered? any other ideas be greatly appreciated
    cheers people
    vl berlina wagon 6cyl
    Jul 2005
    jack up car a bit and get under at back, push body up and down and look for movement at rubber bushes, especially shock absorbers lower bushes
    one of the shockers may be worn out, leaking fluid can be a clue
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    as above and
    grab your pan hard rod and try to wobble it if there is movement the bushes are shagged!
    from experience the replacement exhausts have a habit of banging in some places, diff housing, fuel tank, rear of car near the hangers and even the seat rails under the car.
    Nobody wants to play with me
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    push your tire in with your foot as if your kicking it at the top sort of thing and the car and wheel should move as one if there is movement between the 2 your pan hard rod is shagged.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    The upper control arm bushes are sure to be shot. My VR had the same problem and when I pulled the arms, the bushes were dead as... Cheap to replace, although buggers to remove the old ones, and the improvement will be very noticeable. Panhard rod bushes also clap out and they are very easy and cheap to replace. Do the lot together, evenif they look half decent.
  1. banging at rear
    By sus_calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2008, 12:00 AM
  2. An annoying problem
    By HoldenManDan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2007, 11:08 AM
  3. Very annoying problem
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 04:22 PM
  4. please help - annoying problem
    By =Calais v8= in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2005, 08:11 PM
  5. Annoying Problem...
    By fourstar82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2004, 05:46 PM
