Results 1 to 5 of 5
Thread: problems starting in morning
    Aug 2008
    Default problems starting in morning
    Hi, I have a vl and in the mornings its hard to start, the starter motor moves really slowly. Once I finally get it started and have driven it for a little while, it just seams to be normal again.
    Anyone got any angles I can work on to fix this problem?
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    possibly your battery! remove the filler caps and top it up with boiled/distilled water, also check that your terminal clamps are fitted tightly and your earth to the engine block is clean and tight. cold weather is hell on ya battery, I regularly check it but had the same problem you are describing just two weeks ago.
    Nobody wants to play with me
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    mostly the battery im sure as jatsvl has said. Also the oil in the car is ALOT thicker in the cold mornings and the little starter motor not only has to move the whole motor but the very thick oil that the crank is dipping into.
    But check out ur battery terminals and possibly get new ones ($5 for 2 of em).
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    vl berlina wagon 6cyl
    Jul 2005
    also get some honest place to test battery to see if its wearing out, they dont last very long
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    check your air regulator, go to r31skylineclub.com and look it up in the technical section
  1. HELP! starting problems...
    By tiphanie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2010, 08:42 PM
  2. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  3. Starting problems
    By Emu in forum General
    Last Post: 23-10-2006, 10:11 AM
  4. Starting problems
    By dncc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2006, 04:52 PM
  5. Trouble starting this morning...
    By psycho_circus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-08-2005, 10:13 AM
