Results 1 to 3 of 3
Thread: unusual rack & pinion movement
    maxpower QLD's Avatar
    maxpower QLD is offline has mild super powers
    Xtrail/5spd VL
    Feb 2008
    QLD (the police state)
    Default unusual rack & pinion movement
    hi everyone
    Ok i have a problem With the rack and pinion in my VL . The rack ends seem fine but i've noticed the top part has excesive movement in it and it just seems to wonder all over the road at 120 km/h. Is there any way of being able to tighten it or fix it ? The rack was reconditionded 18 months ago so its not all that old . And i don't have the cash to buy a new one at the moment. anyways here's a picture of it
    Attached Thumbnails Attached Thumbnails unusual rack & pinion movement-rack-pinion-001.jpg
    Quote Originally Posted by VS Omega View Post
    "gonna beat you to the next set of lightes uleh"
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Quote Originally Posted by maxpower QLD View Post
    hi everyone
    Hi maxpower
    By "top part", I assume you mean the input shaft, which is connected to the steering column? If that is the case, yes, the rack can be adjusted but it should be done by somebody who has the correct tools. The movement is caused by excessive clearance between the input shaft worm gear and the rack. Suggest you take the vehicle to a steering specialist who would be able to set the rack up properly for you. Shouldn't require any parts, just time.
    Xtrail/5spd VL
    Feb 2008
    Quote Originally Posted by VYII BERLINA View Post
    Hi maxpower
    Thanx VYII BERLINA , I thought i'd be up for a new rack and pinion but if it's only a basic adjustment on the input shaft then i'l send it in asap to fixed . Cheers mate
  1. rack and pinion
    By hN! in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-03-2012, 06:14 PM
  2. vn-vp rack+pinion input shaft
    By friedchicken in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2008, 11:55 PM
  3. Rack and pinion
    By wondering in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-12-2007, 11:14 PM
  4. rebuild rack and pinion DIY?
    Last Post: 24-09-2007, 10:02 PM
  5. VN Rack and Pinion Problems
    By lealea in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-04-2005, 07:38 PM
