Results 1 to 10 of 10
Thread: Fan Speed Resistor
    VL Berlina Station Wagon
    Sep 2007
    Default Fan Speed Resistor
    Hi everyone,can somebody help me with the location of the fan speed resistor in relation to the air-con.Thanks very much. Martin
    Sep 2007
    Someone must know where the resistors are hidingthat work with the heater blower fan switch and how to test if operatable. Thanks again Martin
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I can't believe no one knows so I will have a guess. It might be where the windscreen wiper mechanism is on the passenger side, under the weather strip. I know that's where it is on a VR. On later models it is behind the glove box.
    MY RIDE
    Sep 2007
    Still couldnt find resistor,but today went over a bump on comes the fan,with all speeds working,so now I need to find the faulty wiring responsible,at least no parts are required I think .Martin
    '87 VL Calais with L67
    Aug 2007
    look in the passenger footwell. there is a black dome. unscrew the screws and out drops the fan. the resistor is in that box area.
    might not be your fan resistor causing intermittant fan failure though, could be your a/c control unit. look at the copper circuit board on it and see if thats dirty. careful that the vac hoses dont come off tho unless you have them marked. hope this helps mate.
    This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
    Sep 2007
    Thanks Panama,do you mean the dome that protrudes thru the lower trim panel under the glove box,the resistor is in there?The ac control unit,where might that be?and is the dome part of the blower motor there.Thanks for your reply.Martin
    Aug 2007
    Aug 2007
    the dome is the arse end or an impeller type fan. the resistor is in the engine bay, on the passenger side once you take the black bit off in the channel that the wiper motor is in like accentstencil said.
    Sep 2007
    The only thing under the cover in channel in engine bay is wiper motor at driver end and blower intake at other,nothing else.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    im not quite 100% sure
    but i recall a simular problem with mine a year or so ago
    i think its built into the ac controls
    the fan speed selector pivots on a point causing the earth point to move across a row of S bends of copper, the further from the start the slow the fan blows as less power will make the distance
    mine had melted/blown a gap in the copper track, so it wouldnt work
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
  1. Vt Fan Speed Resistor
    By gsmrobinson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2010, 01:42 PM
  2. fan speed resistor
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2009, 08:48 PM
  3. How to get to the Fan Speed Resistor?
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-12-2008, 02:28 PM
  4. Fan Speed Resistor? VN
    Last Post: 16-05-2006, 08:25 PM
  5. Fan speed resistor
    By Bec in forum Electrical Wiring / Questions
    Last Post: 06-08-2004, 12:59 AM
