Probs ebay. Or take them somewhere what service injectors.
1988 VL Berlina turbo 5 speed
http://forums.justcommodores.com.au/...ml#post1446411
1987 VL SL turbo 5 speed ~STOLEN~
http://forums.justcommodores.com.au/...ed-manual.html
iv got a set thats done about 10 000km, $60 if u want em
the 60 dollar offer is pretty cheap and good if they work properly, for about 200-250 you can get your original ones taken out, ultrasonically cleaned, rebuilt, then flow tested.
Basically a new injector set.
I wouldn't get VL injectors cleaned when they are this old. They tend to leak from the bodies once they have been cleaned. I have ultrasonically cleaned many, many injectors in my time and the VL ones are always the ones that will tend to leak after time, if they are not already weeping from the bodies.
I will always try to quote for brand new injectors as I know they will be perfect and last for AGES and all with a warranty.
I get my new ones from powerflow injection in Ringwood, Melbourne. They are fairly well priced and are the upgraded green body injectors that have a revised body seal and will not have all the leakage problems that the originals have.
ive only herd bad stories after rb30 injectors were cleaned.both stories involving fire .get new ones..alot cheaper then having ur car burn to the ground trying to save a couple of bucks
the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
Injectors Online - Product Catalogue
$80 each
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
