Results 1 to 12 of 12
Thread: MY VL wont start..but it cranks over
    VL gold 5 Speed manual RB30 1 Owner since NEW
    Sep 2008
    melbourne australia
    Default MY VL wont start..but it cranks over
    hello all
    i am new here and online member of a couple other auto forums
    so-i-give-n-take-help
    but
    MY GOLD VL sl 6 cyl manual september 1986 built wont start..
    but it cranks over ,its always started first shot (and always proud to boast that )but last week it wouldnt start
    undid fuel line at rail and seems good pressure coming out
    put BRAND NEW timing light on various spark plug & coil leads =no spark
    swapped over coil ,REPLACED Crank Angle Sensor brand new............. still the same ,no spark,relay under the fusebox cover clicks on
    looked @ computer codes results are 14,23,24,31,32,14
    ran test lead from pos batt term to POWER TRANSiStOR on DISt (brown-red wire terminal)
    whilst cranking it flashes on-off with,
    with key off OR in acc position TEST LIGHT stays on
    any help /clues will be much appreciated thanx
    spank is offline Still spank'n
    VZ GTO 6.0 WM CAPRICE 6.0
    Sep 2008
    crime downs
    from what you are telling me, and good info by the way, i would say its the crank angle sensor, which is located inside the distributor, not a difficult job and not that expensive really,
    Sep 2008
    melbourne australia
    thanx reply but i have replaced it ,,CAS crank angle sensor brand new couple days ago
    Sep 2008
    melbourne australia
    CODES ARE:
    11 Crank angle sensor circuit
    12 Air flow meter circuit
    13 coolant temperature sensor circuit
    14 Vehicle speed sensor circuit
    21 ignition signal circuit
    23 throttle switch circuit
    24 neutral switch circuit
    31 satisfactory operation (non air conditioned models) air conditioner circuit (air conditioned models)
    32 starter signal circuit
    34 detonation sensor circuit (turbo models)
    44 satisfactory operation (air conditioned models)
    hi thanx reply no i havent .tho i have had the computer out b4
    i was also thinking it maybe the little resistor in the wiring loom that runs under the inner RH gaurd ..just opposite the battery
    Sep 2008
    crime downs
    Quote Originally Posted by etch289 View Post
    CODES ARE:
    last one i had do this had a faulty fusable link, you need to check battery voltage out of the link with everything hooked up, WHILE CRANKING!!!!!if its less than 12 volts or so the link is ***ed, either that or the ecu has had a meltdown! Also check that the battery terminals are clean and tight and any earths that you can seeif you leave the ignition "on" try moving wiring near the battery and the fusable links, if you hear the relays in the underbonnet fusebox click or buzz then you have a poor connection, thats about all i can think of without having the car with me!!
    Sep 2008
    melbourne australia
    Quote Originally Posted by spank View Post
    whereaabouts are u located spank?????????
    disconnected the TPI switch and it sorted of tried to start fire up
    and checked heaps of stuff but still the same no start ..................help
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    just a random shot in the dark, have you got rust in the left hand side of your windscreen,
    maybe water has ran though and soaked your comp causing it to short
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Sep 2008
    melbourne australia
    Quote Originally Posted by VL Berlina 5speed View Post
    no rust watsoever thouroghly checked that area ..pulled out comp checked all terminals looked as new all dry there even the underlay all dry
    thanx tip tho
    vl commy rb30et
    Jul 2010
    nz
    hey man did u get the vl going i think i might have the same problem EEEEK !?!
    vl commy rb30et
    Jul 2010
    nz
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    thread Dig! this thread is 2yrs old, you'd be better off starting your own thread! with your current problems and what you have tried and tested.
    and if you haven't already changed the cas, then that would be a good place to start.
    Nobody wants to play with me
    detox_nath83's Avatar
    detox_nath83 is online now Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    before starting a new thread i would do a search as this has been cover numerous amount of times and i am over repeating my self
    My thoughts :P
  1. vt v6 cranks but doesnt start
    By MY 5.0L VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2009, 11:37 PM
  2. Car Cranks Wont Start
    By GROOVA75 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2008, 11:46 PM
  3. 5 spd 91 VN wagon cranks & wont start
    By lldeanll in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-09-2007, 11:52 PM
  4. Car wont start
    By matty_kar in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-07-2006, 11:32 AM
  5. cranks but wont start
    By stockvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2006, 12:03 PM
