Hey all , i dont have a repair manual yet, so i cant tell which wires i wanna touch, one of my high beams has a habbit of going off over bumps. so i wanna solve the wirring problem, i know its not the control arm or bulbs as ive just replaced them with new..
so what is each coloured wire? i know black is earth..
follow & copy the good side that works and reinterpit on the bad side
just wiggle the wires on the back of the light plug till you find
the loose one or double check the fuse box ive seen some
bad problems with the fuse holder
Hi mate, here's a link to the lighting wiring diagrams for the VL in pdf format.
www.danny8.com/gear/VL_LIGHT_WIRING.pdf
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
