+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 26 to 50 of 50
Thread: thermostat
  1. #26
    ImAHoon! is offline Banned ImAHoon! Executive
    Toyota Camry?
    Oct 2008
    I've tested a Stant brand thermostat, a Trident, and a Nissan one (which was in the car when I got it.
    the Nissan opened about 11mm at 90 degrees.
    the Stant opened about 8mm at 90 degrees.
    the Trident opened about 6mm at 90 degrees, and I took it back and got a full refund. haha
    I plan on replacing the radiator.
    does anyone have any experience with the alloy ebay radiators?
    or can someone point me in the general right direction of a decent quality, brand new radiator?
    thanks.
  2. #27
    Toyota Camry?
    Oct 2008
  3. #28
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher VL Berlina 5speed Monaro VL Berlina 5speed Monaro
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    i have a stant
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
  4. #29
    Toyota Camry?
    Oct 2008
  5. #30
    Oct 2005
    ill tell you when i get the cars up and running
    will be a while though
    i did get one which opens up earlyer and runs cooler, not sure on the temp but i could find out if you really cared lol
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  6. #31
    Toyota Camry?
    Oct 2008
    Quote Originally Posted by VL Berlina 5speed View Post
    it makes no difference, I'm doing the radiator and seeing what happens.
    the photo at the top of the page was towing an empty trailer, up the freeway, at 100km/hr, this was with the Trident thermostat.
    I really expected it to just die, but it didn't!
  7. #32
    Bagged vs caprice sII
    Sep 2007
    Newcastle
    i have seen m brothers Vl get that high but just pulled over and stped ETC, hes bled his system ETC new dayco thermo and still no temp change...
    think its time to get it looked at by a pro
    lol
  8. #33
    Toyota Camry?
    Oct 2008
    Quote Originally Posted by mking View Post
    lol
    I'm wondering if my waterpump could be somehow on its way out...
    anywya, radiator first! haha
  9. #34
    Oct 2005
    if your keen to doing over the cooling system i would change all your pipes aswel when you do the radiator
    theres a mackay rubber kit on ebay for the vl for something like 70ish bucks,
    i bought every pipe new in mackay brand and i spent over $100 easy
    then a week later that came up
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  10. #35
    Toyota Camry?
    Oct 2008
    I bought a kit off ebay for about $70, Gates brand, came with the Stant thermostat aswell.
    it didn't come with replacements for 3 hoses, and 2 of the hoses in the kit simply DO NOT fit anywhere, so I'm not too happy about that.
  11. #36
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Call Tridon, and ask them for the part number for a High Flow thermostat and order it in. Dont run cooler thermos, as they open too early and they dont work in sync with the fans and engine management. I think 180F or 96^c is what it should be. High Flow thermostat gives you the benefit of a cooler thermo while still operating at the correct time and temp, but will run more efficiently......
  12. #37
    commsirac is offline Banned commsirac Calais
    vx
    Aug 2007
    any home mechanic, or any mechanic for that matter should get themselves an infra red thermometer. ~$40
    With just a little bit of logic it allows one to diagnose the problem and avoid randomly replacing everything until the problem is solved.....an okay practice if time and money are no object!
    It does sound though as the thermostat is the problem.
  13. #38
    Toyota Camry?
    Oct 2008
    Quote Originally Posted by vxcalais_01 View Post
    its more like 75 degrees C/170 degrees F
    why should I have to buy a high flow thermo just so it flows as well as a standard one?
    Quote Originally Posted by commsirac View Post
    the original thermostat seems to function fine when tested on the stove top.
    however, in the car, it still struggled to maintain proper temperature, and still got warmer than I would have expected, and took ages to get upto temp.
    so, a new radiator is on the way
  14. #39
    vx
    Aug 2007
    Quote Originally Posted by ImAHoon! View Post
    yes, if you randomly replace everything you'll eventually found out what was causing the problem(you could get lucky and it will be the first item)......or you could diagnose.
  15. #40
    timgte is offline v8 fuel sucker timgte Executive
    Berlina
    Apr 2008
    Default radiator
    Autobarn sell radiators for the VL for $279 brand new.
    From Motorcool
  16. #41
    Toyota Camry?
    Oct 2008
    ah, there's not much in the cooling system after this.
    I had wanted to do the radiator anyway, and it always seemed to take to long to come upto temp, so I replaced the thermostat.
  17. #42
    Toyota Camry?
    Oct 2008
    been working on the car today, while the radiator was out, I decided to do the timing belt as well.
    the belt is pretty much out, I'll be fitting the new one tomorrow
    no real problems as of yet.
    except... how am I going to tighten the crank pulley bolt back up?
  18. #43
    Oct 2005
    leave the radiator out, use a 1/2 inch drive socket or bar braker
    same way you got it off really
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  19. #44
    Toyota Camry?
    Oct 2008
    no, because I got it undone by wedging a breaker bar, and cranking the engine... lol
    I could not get the starter motor off.
  20. #45
    Toyota Camry?
    Oct 2008
  21. #46
    Toyota Camry?
    Oct 2008
    radiator and timing belt done.
    now heading up the freeway, the temp needle gets upto the 3rd mark (4th if you count the first one)
    which is half way, and a lot better than maxed out
    as it gets to the 3rd mark, I think the thermostat opens more, and it drops back to 2.5 or so pretty quickly, then creeps back upto the 3rd mark...
    city driving, it sits just above the second mark, upto about 2.5
  22. #47
    Toyota Camry?
    Oct 2008
    95% sure the car has a blown headgasket, or cracked/warped head....
    so, that was all good fun now wasn't it!
  23. #48
    Oct 2005
    didnt bleed it properly?
    losing all the coolant and making thickshakes?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  24. #49
    Toyota Camry?
    Oct 2008
    no, it has always been bled properly.
    the head/gasket damage must have been done when I towed the trailer up the freeway before replacing the radiator (see pic at top of page)
    but the problem didn't show itself till I replaced the radiator... and the timing belt
    its not lacking power (no more so than it was to begin with) but when you first start it in the morning, it only fires on 5 cylinder for the first 10 seconds or so, and spark plug 6 appears to have gotten wet/steamed, and it slightly corroding/green on the electrodes.
    hmm.
  25. #50
    Toyota Camry?
    Oct 2008
    what the **** am i supposed to do with this thing.
+ Reply to Thread
  1. VT V6 thermostat
    By savage1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2008, 01:07 PM
  2. thermostat
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2007, 06:58 AM
  3. Thermostat
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 09:53 PM
  4. thermostat
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 09:48 PM
  5. thermostat and new fan
    By yobbo88 in forum Electrical Wiring / Questions
    Last Post: 14-08-2006, 05:16 PM
