Results 1 to 4 of 4
Thread: calais pop up connection
    eko's Avatar
    eko
    eko is offline 3kO
    Soon to own vb commy end of year
    Aug 2007
    South Eastern Suburbs
    Default calais pop up connection
    hey guys put calais pop ups on a vl commodore how do you connect the wiring for da pop ups and ideas
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    I've heard people just use a relay connection and wire it into constant and then trigger it from the headlight wire - Probably easier to get an auto electrician to do this for you then get him to run it into an existing loom or get a new loom etc.
    eko's Avatar
    eko
    eko is offline 3kO
    Aug 2007
    i was told dis way connect a wire from da op ups to earth body of viechle den send a positive wire to da lights power cable den send a negative wire to da lights off cable on da instrument cluster or da lindictor stall
    Bax
    Nothing
    Jan 2004
    QLD
    Yeah I'd probably go the relay method with a dedicated 12v source.
  1. dfi to coil connection?
    By Tong in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2007, 06:24 PM
  2. Amp connection
    By myhsv in forum Car Audio
    Last Post: 06-09-2006, 08:18 PM
  3. Gen 111 connection to Laptop
    By Chester in forum Electrical Wiring / Questions
    Last Post: 02-10-2005, 07:37 PM
  4. VT ECU connection to laptop
    Last Post: 28-09-2005, 08:56 PM
  5. Power Connection For amp
    By Spanner in forum Car Audio
    Last Post: 29-01-2005, 11:28 PM
