I take it its private sale mate? if so then ask if its regstd? if its not regstd then ask how long it has been sitting? why was it unregstd? look up under guards for signs of tyre rubber suggesting that's its done burn outs (i.e hoons car) while your there check tyres for wear!! Reach under the car and check for play in the drive shaft, if there,s play then uni,s will have to be replaced!
When you arrive @ the blokes house BEFORE you start the engine pop the hood and check 2 see if the owner has warmed the engine up (they do this so you don't see the amount of worn engine smoke or any nasty/knocks rattles that occur on start up).
Now before you kick her over check the oil and note its color is it nice and clean? or neglected and sludgy?
any signs of metal fragments? or emulsification?? the same goes with the auto box!! also look @ coolant is it nice and clean? or neglected and rusty? are all the belts in good nick or will they need replacing? the same goes for rubber hoses!! any corrosion around radiator pipes and battery terminals??
Now with the radiator lid off start the motor and allow the car to run, listen to the noise of the fuel pump and the water pump both when you go to start the car and while the car is running! is it noisy? suggesting it might need to be replaced? now with the car running get out and look @ the water in the radiator cap, is it oily/sludgy or blowing bubbles? suggesting a blown head? if not and all looks well, then replace cap and give the motor a few good revs (after warm up) preferably with a mate @ the rear 2 see how much smoke she blows!!
Once sitting in the car put foot on the brake and put the car into Drive taking note of the box! does it shift quickly/quietly/smoothly, any clunks from the diff?? and with the foot on the brake apply a little gas to see if the car wants to move easily! if she don't then bands in the box might be worn, and the box will possibly need a rebuild!
also place the car into reverse and note the time it takes to change into gear from drive!!
Ask for service history on both engine, TRANNY and diff!! while your @ it check 2 see what condition the brake fluid/pads are in and how well the booster functions when the car is running i.e is it spongy? also how well do the shocks work? being carefull not to buckle any panels push down on the corners of the car above the shocks to see how well they spring back up!
Now onto the body!
Is the paint faded or showing signs of neglect and left out in the sun? check 2 see that all bumpers match up in color, if the don,t (say the fronts a different color) then start asking as to why it was replaced? and get under the front and start looking for signs of an accident or if the cars been abused!! check all the usuall rust areas front/rear screens 1/4 panels under carpet in boot!
Now the interior!
Is it clean and looked after? vinyl in reasonable nick for its age? or does the car look like its been left out in the 50 year storm??
Now electrical!!
CHECK 2 see if all instrument cluster functions are working and while your @ it look at the coolant guage is the car running hot for any reason in fact check to see if any warning gauges show up i.e oil /battery ect! with a mate outside check to see all front lights/brake lights/ parkers/rear parkers/indicators are working!
once all that is covered then work out what needs replacing out of all that stuff and factor that into your cost of buying! hope this helps mate
