Results 1 to 8 of 8
Thread: pwr light flashing
    berlinabeast is offline Banned
    1987 holden berlina 'rb20e'
    Sep 2008
    Default pwr light flashing
    Hey guys/girls.
    Just re-editing my post as i solved a couple of problems.
    Now i'm having problems with my battery, brand new battery, is holding it's charge, dizzy and everything else is ok.
    But something is draining the power source when im parked, as ill get back to the car and go to start it and the battery sounds like it's almost flat.
    and at times it sounds like the immobilizer is still active because when i go to start it, nothing happens, no clicking or indication of a flat battery. Just nothing what so ever as i turn the key.
    any ideas? if you want to know any more information just ask
    vl berlina wagon 6cyl
    Jul 2005
    the battery may be faulty, make sure the underneath of the bonnet isnt touching the terminals when shut and that the terminals arent connected the wrong way round
    both terminals and clamps need to be clean and tight
    98 VT Acclaim
    Aug 2008
    New Zealand
    i've got the same problem with my VL. I don't drive it much, and if i leave the battery connected and leave it for longer than a week without starting, the battery will only just be enough to start it (if im lucky). so i just leave it disconnected when i park it up. a bit of a hassle but hey it works. but if anyone could tell me as to what would be draining it please let me know?
    can't be the exterior or interior lights as they are all off, im guessing maybe a short some where?
    VT SS S2 A4
    Aug 2005
    98 VT Acclaim
    Aug 2008
    New Zealand
    i'll double check but im pretty sure it doesnt even work.same goes for the glovebox light. thanks for that though
    '87 VL Calais with L67
    Aug 2007
    the regulator on your alternator could be rooted, allowing it to charge enough to keep the charge light off, but not to fully charge the battery. this was happening to me.
    This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    have you checked the battery fluid levels? top up with distilled water or water from your kettle.
    Nobody wants to play with me
    Sep 2008
    Just to update this thread if anyone was having the same problem. I tested the battery and that was the source of the problem. A new heavy duty battery later everything was fine. Or so i thought, it was a mix of a block in one of my injectors and a dude battery (found this out after the handy link for testing the comp ) cheers guys. So this should help anyone who is having the same problem.
  1. Mode light flashing fast
    By longmanfamily in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-02-2007, 05:12 PM
  2. flashing mode light
    By super_6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-09-2006, 05:40 PM
  3. Start up Battery Light Flashing
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2006, 09:58 PM
  4. Computer Light Flashing
    By thisispete in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-05-2005, 11:10 PM
  5. Vx Berlina Airbag Light Flashing
    By tdholmes84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2005, 04:46 PM
