Results 1 to 2 of 2
Thread: changing to a VT booster + master cylinder
    98 VT Acclaim
    Aug 2008
    New Zealand
    Default changing to a VT booster + master cylinder
    hey guys im looking at purchasing a disc rear end for my vl sedan. i've read that i need a different master cylinder that suits the 4-wheel disc brakes rather than my standard 15/16 disc+drum one.
    Will the VL 1" master bolt straight up to my NA booster? will all the brake lines fit straight in?
    Or should I try get the booster with the 1" master as well? If so, will this bolt straight up to the stock mounting bracket?
    Or would a VT master and booster be a better idea? My mate did one on his VR all he needed to do was modify the bracket and bend one of the pipes a bit. But I have heard that to do this for a VL i would need hose adaptors because they are different sizes or something is this true? If so, where in NZ could i get some? thanks
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you could possibly remove the non return valve for the rear brakes from the standard master cylinder to get the rear disks working properly it just presses in there.
  1. Vt Master Cylinder And Booster
    By micheledip in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2008, 01:27 AM
  2. Fs [vic]: Vt Master Cylinder And Booster
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 20-08-2008, 04:26 PM
  3. SA- fs 1"master cylinder / vr brake booster
    By vr-man in forum Parts And Other Items For Sale
    Last Post: 30-07-2008, 08:50 PM
  4. master cylinder + booster
    By orbisfactor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2008, 06:36 AM
  5. Best option for booster and master cylinder
    By AirStrike in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2005, 02:03 PM
