Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VL Holden Commodore (1986 - 1988)
VL Holden Commodore (1986 - 1988) Talk about anything relating to the VL Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 07-10-2008, 08:55 AM
Ride: vl wagon
leslloyd Executive
Default ECU leds not showing up,what now?
Well I've taken readings of the green and red led's.And what's coming up is 14,23,24,31.Appears all correct.
I turn screw full clockwise and engine labours and slows,is this what's termed "get home mode",when all the sensors are disabled?then return it midway where it runs nice.
No other led's come up apart from the above.Mystery!
All i can think of is the AAC not working(what does this do?)
Anyway i think my car uses too much fuel around town although it runs well as far as idle,response,starting all seem perfect.
any clues as to why i'm getting no led's up?
cheers
colin.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 08-10-2008, 08:10 AM
Ride: vl berlina wagon 6cyl
Trade Rating: (0)
harry3 Berlina
some ecus get effected by water that leaks down there from the windscreen seal
  #3
Old 09-10-2008, 05:55 PM
Ride: vl wagon
leslloyd Executive
Yeah,i had mine replaced about 1 year ago because of that,i think it may have been a blocked vent above the firewall that caused that.
I'm going out tonight so i'll see if they crank up while out cruising.I know the old one did about ten years ago.
cheers
colin.
  #4
Old 10-10-2008, 08:15 AM
Ride: vl wagon
leslloyd Executive
Did some multimeter tests yesterday.
When i remove the temp sensor (yellow)wire engine speeds up,don't know if this is correct responce.
The AAC valve((in front of plenium chamber)has a hose leading to the inlet.Blocking this off has no effect on engine speed.Also pulling wire plug has no effect.
Only have to test voltage on oxy sensor today.New one is $86 from Burston parts,Nambour.
I'm thinking AAC valve is the culprit leading to heavier round town fuel consumption
cheers
colin.
  #5
Old 10-10-2008, 10:14 AM
Ride: vl wagon
leslloyd Executive
Opps,not the AAC valve,but the air regulator.
Going by the troubleshooting guide i need to test voltage in the oxy sensor,he doesn't mention the colored wires i should probe though
cheers
colin.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Did my brother buy a lemon or is the car just showing its age? JD General 16 19-05-2008 07:17 PM
problem showing site TRICKEDUP Site Feedback / Site Problems 1 26-04-2008 03:23 AM
new member showing some of his HOLDEN ARTWORK brockgroup3 General 14 06-09-2007 11:22 AM
Showing Speed on dash in vr Joey_19 VR - VS Holden Commodore (1993 - 1997) 9 24-03-2007 02:15 PM
VN showing off isaac_2jz VN - VP Holden Commodore (1988 - 1993) 23 06-10-2005 08:02 AM
Mortgages | Web Advertising | Loans | Mortgages | Synchronization fast and easy | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
