Results 1 to 25 of 25
Thread: Did holden EVER make a black 308?
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Default Did holden EVER make a black 308?
    My commodore apparently has a Black 5.0 in it. But the castings on the block say 308. But they never made a black 308, only the 304...
    Did they ever make black 308 for racing, special edition... well at all? This is making me question my cars motor.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    VK's use black 308's hey? And also wat about VL's?
    Maybe the motor has just been painted?
    VS daily // V8 Hilux // Merc 190E
    Feb 2007
    WA Perth, Joondalup
    I thought all VLs were 304? And for VK, the early V8s were 308 but I dunno if they were black or whatever...
    VP Executive R-spec
    Jan 2005
    There were black 308s in the VKs before the change to 304, the only race spec 308s were the L34 blocks in the late 70s. The A9L 304s VK-VL? were similar and the VN- onwards are stronger again than the L34/A9L bottom ends
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    didn't the A9L and L34 both have 4 bolt mains? and doesn't the vn 304 onwards have 2 bolt mains?
    VE SSV Sportswagon, VK race car, Kwaka ZX12R!
    Oct 2003
    Bayside Melbourne
    Quote Originally Posted by hartsc View Post
    ...nope...and yes!
    pic of my 308 A9L from my VK
    yeah pic is upside down.....
    Smitty...with the VE SSv SII Sportswagon, VK race car and... Kwaka ZX12R
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    right... cause my motor did come from another car and according to many people it was a black one. So, my motor is a VK i guess?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by Paiste402 View Post
    What's the engine number prefix? - VZ or VT? (308's out of the VK's)
    and 3 Dangerous non ABS VN's
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    Quote Originally Posted by 88GreenVN View Post
    no idea cause i cant find the engine no. I think someone may have taken it off for some reason
    88GreenVN's Avatar
    Jun 2006
    The only reason someone takes an engine number off a block is to make it a HOT engine without mods
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    well isnt the engine no. on the heads near the first cylinder? Cause this has different aftermarket heads on them with no number castings. Might be y i cant find the numbers
    88GreenVN's Avatar
    Jun 2006
    Engine number will always be on the block somewhere.
    DANNY8's Avatar
    Apr 2004
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    Quote Originally Posted by DANNY8 View Post
    What about when the block is decked? That can wipe the engine number off.
    Decked may i ask?
  15. #15
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Decking is when they mill the top of the block. For the life of me i cant remember where the numbers are on v8's but that is the easiest way to tell which year it is out of.
    You have to consider it may have been painted all early blocks have 308 cast onto them then efi's have 5.0L cast onto them
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  16. #16
    vn ss
    Sep 2007
    central coast
    front of block up near head area i think it is sposed to be the right side?
  17. #17
    vn ss
    Sep 2007
    central coast
    thtas just from memory its something i havent really taken much notice off but thats where your number should be and if block has been decked itr could very well be gone happened to a guy at my work his engine ended up with it stamped on the wrong side.....
  18. #18
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I had a look at one at work today and your right, its on the front right hand side. It would be possible to deck it off but you'd have to be not paying attention or not have the right sized cutter.
  19. #19
    vn ss
    Sep 2007
    central coast
    yeah i thought it was wierd when the guy at works ended up decked off but hey wasnt my car so i didnt ask too many questions...
  20. #20
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    im sot sure as i didnt work on the motor when it was being worked on. I would bet that it was decked cause its had quite alot done to it then it was repainted.
  21. #21
    VL Berlina Wagon
    Sep 2006
    My VL also has the 308 ,it was standard alot of people try to argue with me about it being a 304 but its the same as yours a 308, have had it stroked and recommend i to anyone after loads of torque.
  22. #22
    VP Executive R-spec
    Jan 2005
    Just to update, a friend of mine bought a 308 the other day, it carries the VL engine number but has 308 cast in the block. Obviously it's a 304 on the insides since that's the only crank they made then but it seems they took a while to change the blocks casting to 5L
  23. #23
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Holden changed from the blue motor (VC - VH) to the black motor with the introduction of the VK. The VK's were 308's till about half way thru their model run when Holden reduced it's stroke slightly bringing it down to 304 ci (Slightly less than 5.0 litres) because of the new Group A touring car rules being introduced for 1985.
    So yes they did make a "Black" 308.
    No. The first Holden 5 Litre to get 4 bolt mains (from the factory anyway) was the VN SS Group A. The VP GTS and VP Clubsport 5000i also got 4 bolt mains. These blocks typically have a VK engine number prefix (nothing to do with the VK Commodore though).
    Another reason could be if the block has been decked. Engine numbers often need to be re-stamped but aren't after that operation.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  24. #24
    VK
    Nov 2008
    i just got a 'black' 308, but sure of what it came out of. Engine number starts with VJ ...... any ideas, and would it be 308 or 304 ?
  25. #25
    SL/ENUT's Avatar
    SL/ENUT is online now The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    thats a 304, out of a VL Commodore
  1. For Sale : Holden Commodore VZ SS Black,R8 Rims QLD
    By Anfernee0525 in forum Vehicles For Sale
    Last Post: 12-10-2008, 07:58 PM
  2. F.S. (S.A) Holden RB Gemini- Would make a gd runabout
    By GTP 85 in forum Vehicles For Sale
    Last Post: 04-06-2008, 08:06 PM
  3. Black VX II Supercharged S pack LOADS OF PHOTOS (My first holden V2)
    By Lloyd1986 in forum VT - VX - VU - WH - V2
    Last Post: 05-01-2007, 10:01 PM
  4. Holden 5speed off black motor, exellent condition
    By The 3 Brothers! in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-06-2006, 10:25 PM
