My VL was slowly leaking water from cooling system, I replaced radiator cap and checked everywhere for leaks but no sign, eventually added a can of leak stopper which did stop leak, it wasnt leaking under dash from heater either
does this mean I had a head gasket leak of some type and the water was being sucked into engine?
I thought the RB 30 engine didnt have head gasket problems...
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
You may have a leak from your heater hose, and you may not see it as the water would evaporate when it hits the block.
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
could be a small leak from the radiator core. can be real hard to spot cos it dries up real quik as above.
thanks for all of that will check it all
mate have you checked the welch plugs?
didnt think of them, the leak stopper cure probably wont last long
I was working on a car the other week that had a slight coolant leak. Turned out to be the overflow bottle had a crack in it and the coolant was being forced out the crack
Originally Posted by Reaper:
Originally Posted by Jecs:
heater core ? have you looked inside the car
