well i cant recall as its been over a year and half since i took my extractors off and now ive just come to put a turbo manifold on
ive oredered some exhaust nuts but i cant recall if there is ment to be a washer on them,
im tending to say it would have spring washers, can anyone verify it for me?
studs are all new so they shouldnt be a prob
cheers
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
Thick - about 3 or 4mm - flat washers only.
are these for a rb30? or what you are using on your v6
as the rb30 requires the studs to allow for the manifold to expand and shrink
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
yea there is ment to be a washer on em .. there about 3 mm thick flat washer i think i have a fair few laying around somewhere .. if i get a chance ill dig em up and double check the thickness
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
yes 3mm flat washers then spring washers! if you don't use the washers you will run out of thread and the manifold won't be tight.
Nobody wants to play with me
