Hi there all,
Has anyone had trouble fitting this gearbox to a NA VL..... If so can someone tell me what I need to make it work.....As far as i know it is not a straight forward fit.......
Simon
Lets work as a TEAM and do it MY WAY!!
flywheel and clutches are diffrent dimensions on NA and turbo
need manual tail shaft
pedal box
clutch slave cylinder and resiour
the tunnel metal cover
and trim
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
Thanx for the reply VL,
I currently have a NA 5 speed manual gearbox in my car. So I will need a different clutch and flywheel does that sound correct?
I also heard that the tail shaft yoke is different.
Simon
I can't remember to be honest. I think it may be. Tailshaft will be the same.
Should be a pretty easy swap though.
