Results 1 to 9 of 9
Thread: engine missing under heavy acceleration
    vl berlina wagon 6cyl
    Jul 2005
    Default engine missing under heavy acceleration
    my RB 30 is now missing or cutting out under heavy acceleration only and only when warmed up, otherwise it runs well
    it restarts after cutting out
    what could it be? I looked inside the dizzy head (OK) and checked the electric plugs on the crank angle sensor which are clean, coil electric plugs both clean
    what else can I check,? plenty of petrol in tank and it hasnt done this before
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    How good are the leads? Do they "light up" at night?
    and 3 Dangerous non ABS VN's
    Jul 2005
    berlinabeast is offline Banned
    1987 holden berlina 'rb20e'
    Sep 2008
    Lol sparks in the dark? lol im guessing he's talking about checking the leads and plugs.
    Remove your spark plugs (one at a time) then plug them back into the lead, (have a very insulated pair of plyers, or hold the plyers with a cloth) then hold the spark plug (with the lead attached) just a few mls away from your engine bay, you should see a light blue spark and hear a 'crack' sound.
    If you see orange sparks and no crack, then either your lead or spark plug is on it's way out,
    To test your lead, get a brand new spark plug out of the box and retry the same method.
    If it's orange again, your leads pretty ****ty, if it's light blue and then you hear the crack then it's your spark plug that needs changed.
    My mate had this kinda problem before, his petrol filter was clogged a wee bit.
    Also check your air filter, and make sure all hoses are not cracked (similar problem happened to me, but it was a hole in my air hose)
    Umm, that's all i can think of for now. message me through private messenger and give me a whole work down on the problem, i maybe able to help after i talk to my mate after uni
    Jul 2005
    problem eventually traced to a faulty dizzy module, less than 12 momths old and installed by a local auto electrician who I wont patronise anymore, a cheap unbranded one that caused engine to stumble sometimes under heavy acceleration and sometimes to cut out, but it always restarted
    also I note dizzy has no gasket under head, am pretty sure there should be one to keep dirt out
    starfire vc's Avatar
    starfire vc is offline now on 10 pound
    VL turbo, RB30ET VH wagon, 64 EH in the build.
    May 2007
    Brisbane,North
    yep was goin to say c,a,s .they break down under load.and the engine will pop n fart and carry on.i was told if a c,a,s was on it way out it will just stop.thats not true.ive experinced it a number of times now ,cars that run with c,a,s on the way out.ive allso boght one that ran for only 3 weeks then stoped.. absolute c hunt of an idea
    the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
    Jul 2005
    since these dizzy or crank angle sensor modules arent cheap, it would be a good idea to get a good quality one, preferably with a well known brand on it, mine had nothing written on it at all
    '87 VL Calais with L67
    Aug 2007
    i'd say coil pack. we get that a lot at work.
    This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
    VL Commodore
    Oct 2008
    Glad to hear it's sorted. I had the same problem but i changed leads and plugs and all was alright.
  1. VT V6 constantly missing under acceleration
    By BrentVR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-11-2010, 05:23 PM
  2. Rattle under heavy acceleration
    By VSB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2006, 07:19 PM
  3. Clunk during heavy acceleration
    By Brett L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-05-2006, 02:16 PM
  4. Can smokes under heavy acceleration
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2006, 05:05 PM
  5. loud whistle during heavy acceleration.
    By chevsta_04 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2004, 09:00 PM
