our family has owned this car since 1993. we love it. was getting fantastic km's which was 550 on regular. It has taken a turn for the worst, it now has 350,000 kms on the clock and still has the original motor and transmission and is completly original from factory.
The turn for the worst is it now only gets 350km's per tank of petrol. which is 200kms less than previous. and especially now that we run it on 98 octane it has made no difference
I'm asking for any sort of advice to make this engine drive to near new, increase economy and power. One thing i could think of is getting the engine re-bored and have slightly larger pistons inserted as i think it is having trouble with compression. oh well, any advice would be appriceated, but, we still want to keep the car as long as we can without changing the engine [centimental value & keep it original from factory]
thx guys.
Brent
have u had the injectors serviced
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
check injectors,
o2 sensor might be stuffed now
coolant temp sensor
afm settings to stock
this should keep the car running in top order if all maintained
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
fuel filter, clean throttle body threaten the car with metal recycling idea
i'd start off with a compression test - will give you a good idea of the condition of the actual motor.
Does it burn any oil?
has it been regularly serviced?
