Results 1 to 15 of 15
Thread: how to change a vl ignition barrel
    eaton v8's Avatar
    eaton v8 is offline my little sleeper
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
    Default how to change a vl ignition barrel
    so how is it done????? im sick of swearing at it and carnt figger it out
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    the following is when the steering column has been removed from the car follow the instructions for the lock cylinder only you DO NOT need to remove the steering column!
    1. remove steering wheel
    2.lower column cover
    3.indicator switch mechanism
    now the igniton lock cylinder
    also you may need to break the slot with a screwdriver, and press th clip with a piece of hacksaw blade or paper clip or similar.
    Attached Files Attached Files
    Nobody wants to play with me
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    Quote Originally Posted by jatsvl View Post
    dead set legend it worked and i got it back together ok new problem the horn now dosent work it just blows the fuse any ideas or hints
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    I am not sure about the horn other than, that fuse is the brake light and electric aerial fuse also. you could try the horn relay in the fuse box.
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    so basically this thread is about how to steal a VL commodore with your own ignition barrel and key. lol
    no longer a hoon by association - the commodore is gone
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    yeah or how to replace your ignition to help prevent your car to be started with any vl key....
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Quote Originally Posted by eaton v8 View Post
    it did work before i changed the barrel now it wont play ball
    if that is the case then it would have to be the single wire behind the horn pad or the springs behind there take it off again and just check it all looks ok
    oh and also maybe check the contacts on the back of the steering wheel (you know the round copper strips) maybe they got a bit of grime on them when you removed the wheel.
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    social's Avatar
    social is online now Commodore Enthusiast
    2006 6.0L VZ Thunder
    Nov 2008
    South Aus
    hey guys,
    Just wanted to kno, the technique that youv posted up is only possible via having the previous key, turning onto ON and then removing the ignition barrel, wat about if you lost the key? How do u get it to on to take the barrell off?
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    you would use another key or you would pull the barrel out just like a thief would so you can activate the ignition with a screwdriver
    social's Avatar
    Nov 2008
    South Aus
    lol the barrel dsnt just "come out" and i dont intend on wrecking the actual chamber piece it sits in either..
    vs calais eco
    Sep 2006
    Disney land!
    haha must be ignition barrel failure time as mine just went on the missus while she was up at the shops! However on the VS all you have to do is remove shroud from around steering collum and put key in ignition turn to on position and there is a small hole on the side of the lock mechanism and all ya have to do is get a piece of wire in there and the whole cylinder just slides out!! Was awesome as i was about to go hard @ it with a crowbar but the old man was there to help me out and tell me what to do
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Quote Originally Posted by Vn_Manual08 View Post
    well in that case it is a mobile locksmith for ya then mate!
  15. #15
    VL Vacationer Wagon
    Jun 2009
    Hampton Park
    Default Can't remove ignition barrel *NOT LIKE OTHERS*
    Hi,
    I removed my ignition barrel, easy- since the long pin thingy wasn't connected (and car could be started with anything). Got a new one, tried to put it in, didn't go in easy, used hammer and got it in.
    Once in, the key wouldn't turn the barrel (it was a little touchy beforehand) so i thought i'd remove the barrel. It doesn't come out!
    I tried screwdrivers and blades in the slot to push the pin but it wouldn't come out still.
    After constant playing around with the steering column the whole assembly that holds the ignition came off and hit me in the face. (The part that holds onto the metal rod that starts the car broke off).
    Now that have got this whole assy off you would think removing the barrel would be easy, no. I've tried everything lifting the pin, pushing and rotating and still it wont come out, i have drilled holes in the front, back, and the barrel itself and i just can't get it out.
    Does anyone have any ideas or do I have to replace the steering column?
    Cheers.
  1. ignition barrel
    By 235rwkw in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2007, 07:26 PM
  2. Ignition Barrel
    By Vk_stock in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-03-2007, 12:32 AM
  3. Ignition Barrel
    By ElDubya in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2006, 06:45 PM
  4. Ignition Barrel
    By VKnVLCalais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-12-2005, 05:38 PM
