Results 1 to 12 of 12
Thread: Someone please help me with this issue.
    vx s pac
    Nov 2008
    Question Someone please help me with this issue.
    Hi, everyone. i have a 1987 vl executive, and everytime i hop in the car it has a really strong smell of petrol through-out the car??? anyone know what it could be? the only thing i can think of is.... it has a petrol leak somewhere or its running rich on petrol.
    thanks.
    VT SS S2 A4
    Aug 2005
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    maybe check your evaporative system, these hoses are very cheap and crappy and are probably all broken, they are pretty easy to replace.
    take the cover plate off (4 screws) behind right rear wheel. also check the charcoal cannister and the attached hoses.
    Attached Files Attached Files
    Nobody wants to play with me
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    id go with the injector.. had the same problem with my old silver one.. just stick ya head around the injectors while its running and youl soon find if any of them are leeking
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    as jatsvl said - wouldn't be many vls left that haven't had those hoses replaced. worth doing. remember petrol evaporates quite fast so there might not be any obvious signs that those hoses are actually leaking.
    vl berlina wagon 6cyl
    Jul 2005
    you will need to check the entire fuel system, leaks from petrol tanks do happen, look for petrol on ground where car was parked
    remember that leaking petrol washes away dirt and mud so look for any clean areas
    there are several evaporation hoses from petrol tank that eventually rot, releasing petrol fumes, removal of tank is needed to replace these hoses, if the fault is only from these hoses, the cars seem to run OK in this condition
    vx s pac
    Nov 2008
    Yer the car does run fine.. just has a strong smell of petrol in the car. so you think it is the hoses? not a leaking injector? how much is an average price to get it changed? or is it easy enough to do yourself?
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    you can do the hoses yourself - have a look - if they appear stuff go to supercheap and buy some hose and some new clips/clamps and go for it.
    vl
    Aug 2008
    fill the tank with fuel. go for a run around the block and when you stop have a look at the right hand rear mud flat and see if there is any fuel stain on it. if there is you have a leaking pipe.
    also do not over fill the tank unless your going to drive over 50 km straight away
    good luck
    vx s pac
    Nov 2008
    Ok ill go down to the shop to get some hose... is there any specific hose i need?
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Quote Originally Posted by peter smith View Post
    good luck
    I would not recommend doing that because if there is a leak you will have to remove 50lts of fuel to fix it.
    first you should locate the source of the smell before buying any parts the "evaporative system" was a possible source suggestion, if you are sure it is that, then reach up under the bumper where the filler is and pull a piece of hose off take that and go get some.
    other suggestions were the leaking injectors and the fuel lines front to back under the car and in the engine bay right hand side near the plenium chamber.
  1. VS Oil Issue
    By Mecgun in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2008, 09:56 PM
  2. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  3. Here's a new one... (VE Issue)
    By CSP in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-04-2008, 05:33 PM
  4. VN HSV +6 issue
    By And_ROOS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2007, 03:25 PM
  5. Cause of an issue???
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2006, 09:42 PM
