Results 1 to 8 of 8
Thread: VL Coil
    VN Sedan
    Jan 2007
    Latrobe Valley
    Default VL Coil
    me son and his mate degreased & washed his engine in his VL last week.....hasn't been able to start it since....he was told it could be the dizzy, replaced that today, still no go...I took the lead off the dizzy cap from the coil and had no spark at all.....could it be the coil has died?....if so, how much would another one be?
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    did you replace the whole distributor? or just the cap? with new or 2nd hand? is the rubber boot on the dizzy(crank angle sensor) plug sealed or torn? may have water or degreaser inside the plug
    check your fuses.
    Nobody wants to play with me
    VN Sedan
    Jan 2007
    Latrobe Valley
    Quote Originally Posted by jatsvl View Post
    check your fuses.
    changed the cap first as his was cracked....still wouldn't fire, then changed the entire dizzy....didn't know about the rubber boot, so will check that today. But shouldn't there still be spark from the coil to the dizzy?
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    the plug for cas send s the message to the ecu then to the coil,
    VN Sedan
    Jan 2007
    Latrobe Valley
    so it could be the cas then.....do the VLs give any error codes like the VNs?
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    get an air blower onto every single plug in the engine bay
    they tend to get water in the rubber boots that slide over the actual plastic connectors, so it's a bit of a pain to get out.
    I've had this happen a few times - usually the multi pin plug on top of the dizzy.
    and yep they do have error codes - you can find out on wiki.r31skylineclub.com on how to check them
    VN Sedan
    Jan 2007
    Latrobe Valley
    VN Sedan
    Jan 2007
    Latrobe Valley
    thanks for the help and pointers.....car started and is running fine again
  1. Vn v8 msd coil
    By vnv8driver in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2008, 11:46 AM
  2. coil box
    By tomdaniels_24 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2008, 12:50 AM
  3. VT Coil on VN?
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2006, 03:41 PM
  4. keep the coil dry
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-11-2005, 10:09 PM
  5. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
