i have a vl 6cyl just had exchange motor put in, the cars factory auto the new motor came from a manual setup n we've left it auto. everytime the ignition is turned on the fuel pump fuse blows, i disconnected the pump, still blows. should i be looking at wiring or the ecu?
be looking at your wiring 1st.ecu wouldnt be the cause of your problem
the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
