i have a vl 6cyl just had exchange motor put in, the cars factory auto the new motor came from a manual setup n we've left it auto. everytime the ignition is turned on the fuel pump fuse blows, i disconnected the pump, still blows. should i be looking at wiring or the ecu?
wiring, the ecu should not be a problem.
got any ideas where in the wiring i should look first 2 save pullen the whole interior apart
To start I would check the fuel pump wiring to make sure that there are no exposed bits of wire touching any part of the body.
i just put a thin as piece of wire where the fuse goes, it ran without the wire getting hot so i put the fuse back in an problem solverd cheers 2 all that helped
