Results 1 to 9 of 9
Thread: Tell me a story VL boys
    VP Executive R-spec
    Jan 2005
    Default Tell me a story VL boys
    I was just wondering what date/VIN or Engine number did the engines with the drain plug start. And also if it was right at the begining of series 2 how to I identify a series 2 from a series one. I'm most likey buying one online so I need to be able to tell this stuff from pictures. Also what's the difference between the SL and Executive and why is the SL 30 kilos lighter? no air con or what?
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    exec is next model up from sl , so prob had things like security covers inside doorskins, a/c, etc
    SIR LS1
    the two ton go kart
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Holden have never referred to VL (or VN) as series 1 or 2 cars. VQ (or VP for SWB) were the first models with this.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VP Executive R-spec
    Jan 2005
    Well I dont really care if Holden called them series one or two I just want to know when they had a major update on the VL, ie series 2
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Its just easyer saying S1 S2, cause there should have been a S1 and S2 with the VN cause of alot of differant changes like the 91vn with the VP motor.
    ~ VN POWER ~ Click the scales
    VP Executive R-spec
    Jan 2005
    I've done a bit of googleinvestigationing
    Late 87 seems to be the date the blocks changed, When the turbos were released
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    august 87 was the change i believe,
    non turbo block vin ends with a6 turbo block ends with a8
    na (series 1) block
    turbo or series 2 have holes drilled here with bolts plugging them off
    exec and sl
    sl had power steer and ac optinal
    standerd on exec if i recall correct
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    Quote Originally Posted by STEALTHY™ View Post
    if u really wanna get picky there was a series 1 and 2 in the wb statesman deville and caprice back in the 80s .. then it never came back until the vq
    but pretty much holden chopped and changed the vl for 16 months from the production date so for pretty much more then half the production run of the vl it was constantly changing.. so if aim for a model with a later production date
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by VLDavo View Post
    Just Commodores, not just Holden
    Its just like me saying the VP was the first international series, when it was infact the 2nd, it was just the first in the commodore bodied range, But you knew that yeah?
    cheers sexy
  1. Keep those laptops off your lap boys
    By holdensupporter2005 in forum The Pub
    Last Post: 15-02-2008, 06:33 PM
  2. My Boys Beaut SS Ute
    By jamo in forum Miscellaneous
    Last Post: 26-09-2006, 10:12 PM
  3. One word Story(the actual story)
    By minux in forum The Pub
    Last Post: 11-12-2005, 10:36 AM
