Results 1 to 24 of 24
Thread: Keepin the car running issue
    VLCT, Jetski, 180sx
    Apr 2005
    Docklands, Melbourne
    Default Keepin the car running issue
    Here's my problem with my car atm
    Basically it died while driving about 60km/h, no jolts..
    After every tom, **** and harry saying it was the CAS
    I replaced the dizzy itself as it was seized, the reason I now know why I lost power that night.
    New bearing pressed in, shaft was cleaned, new cas, new rotor button, new cap... so basically a rebuilt one.
    Although the VL manual says to set TDC at 0 degrees it wouldn't start, even after I set the rotor button on #1.. So I put it at 15 degrees and she started.
    First time it ran ok for 30mins. Had it idling for 10mins before I took it for a short drive to check for pinging and detenation... all seemed ok
    Just a street away from home, it started jolting and at first I thought it was a lead came off as it felt the same as when it did it a while back but wasn't it.
    I put it down to a timing issue and got a few mates to look at it but still were a bit stumped on it and has gone way past my knowledge.
    Got my hands on a timing gun, but noticed it doesn't start to flash unless you increase the revs to about 2000rpm +
    A few minutes later it stalled. I have to adjuast the TDC to 15 degrees each time I wanna try and start it. It's giving me the absolute ****s and yeh
    Any ideas??
    HOLDEN4life's Avatar
    HOLDEN4life is offline Power of The CALAIS
    Vl Calais
    Jan 2007
    liverpool (western suburbs sydney)
    VLCT, Jetski, 180sx
    Apr 2005
    If 2 mechanics and an auto elec couldn't figure it out, how am I supposed to?
    maybe???
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    VLCT, Jetski, 180sx
    Apr 2005
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    tryed you cas plug?
    my old daily stopped randomly while driving at 50ks
    took me a while in the dark to figger it was the inside of the plug, one of the cables had broke off
    set it to TDC and get someone to turn it over while you wiggle the cas plug, see if that makes a diffrence
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VLCT, Jetski, 180sx
    Apr 2005
    While wiggling the plug while on acc, the fuel pump you hear go on and off.
    Changing plug atm..
    See if that makes a difference
    VT spac super6
    Nov 2008
    Riverton sa
    i was running 18degrees advanced with no probs in my vl...
    if the gun isnt picking it up could be a weak spark get an old plug that you know works n check each lead... could be a dud coil
    and to set your timing... have #1 at TDC after exhaust stroke, line rotor up with #1lead on dizzy cap and then reinstall dizzy be sure to take notice of which way the rotor rotates as it slots into place and compensate by ajusting the whole dizzy
    VLCT, Jetski, 180sx
    Apr 2005
    CAS plug changed and although it seems easier to start.
    Keeping the revs over 1000rpm due to a lumpy cam, after just a few minutes it wants to stall and does
    Took it a few goes to get it goin again and same issue, stalls after a minute or 2.
    VT spac super6
    Nov 2008
    Riverton sa
    id say deffinatly electrical
    electrics play up when either hot or cold
    try another coil if you have one
    VLCT, Jetski, 180sx
    Apr 2005
    VT spac super6
    Nov 2008
    Riverton sa
    okay so dizzy is practicaly new, coils been checked.. next bet is leads and plugs..
    do the computer diagnostic and check for fault codes, see if anything comes up mate
    VLCT, Jetski, 180sx
    Apr 2005
    Plugs have been changed.. was due for them anyway
    Leads were checked as I have another set and same issue, so there ok.
    Doing a dignostic check on a VLT ECU is the million dollar question.
    They've been known to show codes even when nothing is wrong.
    It shows every code except the starter circuit
    VT spac super6
    Nov 2008
    Riverton sa
    got a spare oxygen sensor laying round?
    possible its that too..
    check the exhaust for excess black smoke
  15. #15
    VLCT, Jetski, 180sx
    Apr 2005
    Exhaust seems normal when it's running of course... lol
    Doesn't the oxy sensor come in at higher rpm's tho?
  16. #16
    VT spac super6
    Nov 2008
    Riverton sa
    oxygen sensor works with the afm to tell the computer how much fuel to give etc
    question
    when it starts to miss and try stalling.. what happens if you give it any throttle?
  17. #17
    VLCT, Jetski, 180sx
    Apr 2005
  18. #18
    VT spac super6
    Nov 2008
    Riverton sa
    by that id put it down to lack of fuel..
    check the fuel supply at the fuel rail mate
  19. #19
    Oct 2005
    clogged cat
    some one had a running issue ages ago and the cat was collapsed blocking it, barely ran or idled.
    the engine can get the gas out and sufficates
    might be a food for though
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  20. #20
    VLCT, Jetski, 180sx
    Apr 2005
    I think it's time to get the pro's to look at it.
    It's going into the shop 2moro
    Thanks for the help guys
    Will post up what it was when I find out...
  21. #21
    Oct 2005
    hope your sending it in to a reptuable vl place
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  22. #22
    VLCT, Jetski, 180sx
    Apr 2005
  23. #23
    VLCT, Jetski, 180sx
    Apr 2005
    They found what they think is the problem
    The bearing in the dizzy is ****ed and told me whoever put it in, didn't put it in properly.
    Gonna fit a new one in and check over a few other things for me and I might get them to do my pumps and filter while it's there.
    Would of done it myself, but the lines feel like there been superglued on.. lol
  24. #24
    VLCT, Jetski, 180sx
    Apr 2005
    Got that problem fixed..
    Had it for a 2 days and now my box decided to give way
  1. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  2. VR Fuel issue and running rough
    By Sgt Santa Cruz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 09:45 PM
  3. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  4. LPG/VT Issue
    By tdub in forum The Pub
    Last Post: 30-05-2006, 07:28 PM
  5. Keepin' up with the Ricers.
    By MynewVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2005, 03:47 PM
