Has anyone got a picture of a vl k frame prefferably looking from in fornt of engine bay or showing where the engine mounts bolt to. Just want to check if i have one in my vn already
Cheers Pub
Originally Posted by Smidy
for a 6 cyl or v8, i have a 6cyl lying around here and also a v8 one which is in my calais, the v8 one will be the same as the vn one but would thing the engine mounts would be diffrent for the 6 and v6
im pritty sure i have a front on shot of a vl6 k frame, ill have to look though all my photos though and find you it later on
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
Ok cheers Vl Berlina I had a look through your thread and saw it but its a bit dark and hard to make out the engine mounts by the way great project you got there will look awesome when painted
Moff man wheres in oz are you located? I have a factory v8 calais but the guy i bought it off took all the v8 running gear he said he'd chuck in a vl k frame or a v6 one that he had lying around. I think its a v6 one but i can hope its a vl kframe maybe you guys could look in my albums and take a look at one of my pictures and tell me if its is or not
vl 6
Commodore VL K frame & Accessories - eBay Other Suspension, Steering, Suspension, Steering, Car Parts, Accessories, Cars, Bikes, Boats. (end time 07-Dec-08 10:55:04 AEDST)
vn 6
http://cgi.ebay.com.au/VR-Calais-V6-...1%7C240%3A1318
about a month ago there was a better set on a diff one which i was eyeing off but didnt save any of the pics
vl one has diffrent angles on the stiffners near the mounts
vl ones are straight 45s and the vn one goes 45 degrees then straight back.
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
Ok looking at that ive got a v6 one by the looks oh well no biggie. Thanks mate i will watch that one not far from me $20 isnt bad. Do you know if the controlarms are different on vn's? I know they all use the same bushes i think length might be an issue
well i would assume they would be the same,
the vn vl use the same strut,hub so i doubt ones control arm would be longer as it would have a diffrent strut set up to cope with the angle to reach a longer control arm
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
