Results 1 to 8 of 8
Thread: someone please help me with this.
    vx s pac
    Nov 2008
    Default someone please help me with this.
    Do vl belinas and vl calais have an accesory switch? because i have an excutive.. and it doesnt seem to have one.
    Also how much would it roughly cost to get calais pop up lights, power mirrors and a power intenor installed by an auto electrician?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by kizza_VL View Post
    accesories as on the ignition?? all the vls have it
    if your radio doesnt run on acc its wired wrong
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    vx s pac
    Nov 2008
    Oct 2005
    haha ive forgot it was backwards too, been driving a vs for too long
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    ImAHoon! is offline Banned
    Toyota Camry?
    Oct 2008
    Thanks but its ok i found it. i didnt know i had to turn it backwards.
    I'm not sure if you're meant to... haha, thats what mine does, but I have to wiggle the key around and almost force it... lol
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Quote Originally Posted by ImAHoon! View Post
    thats very common for the age alot of them don't work at all you could try a new key but it just maybe the ignition barrell itself.
    if you turn your acc's on forward to use the radio or lighter circuits the fuel pump primes and the air flow meter gets very hot.
    Nobody wants to play with me
    sed8's Avatar
    sed8 is offline commodore nut
    vr ute @ vk calais
    Feb 2005
    brisbane
    early commos have the turn back to get acc feature unless your ignition is loose and then it can be hard to find after owning more than a fair share of vh-vl cars some work some dont, as for the aerial and front end the front if it comes with full wiring harness will plug into factory harness as their is plug on the car loom behind the headlight for the pop up lights sl's may not have this depending on the car and its options cause some of them depnding on build date has different things on them,
    if it doesn't have a lion in the badge it not worth having
    detox_nath83's Avatar
    detox_nath83 is online now Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    AFM will get hot because it is a Hot Wire Setup. Once started the airflow will cool the wire.
    The ECU measure how much cooling the wire is getting and adjust fuel mix to run the engine.
