Results 1 to 13 of 13
Thread: how long before changing cam belt
    vl berlina wagon 6cyl
    Jul 2005
    Default how long before changing cam belt
    Ive been told that cam drive belts for the 6 cyl engine can be left longer than recommended as their construction has improved a lot since the VL came out in 1986
    so how many KMs are safe before replacing it?
    apparently its a big job to get the belt cover off to inspect the belt, so most mechanics put a new one on then
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    well its normally 100,00km
    you find this is still reckomended on newer cars,
    my mums daewoo which is 05 says do it at 100,000
    and my dads old rex (my01) was due at 100,000
    its bassically like a power steer belt or alternator, it can snap at anytime
    you could prob get more then 100,000 but its up to you,
    risk getting stuck out nowhere or get it done
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    ImAHoon! is offline Banned
    Toyota Camry?
    Oct 2008
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    the vl has a recommendation of 95,000kms or 57mths with the better belts available it allows you a bit of extra time I wouldn't go past 110,000kms thou, prevention is better than cure.
    Nobody wants to play with me
    Toyota Camry?
    Oct 2008
    Quote Originally Posted by jatsvl View Post
    I wonder if mine has ever been changed
    Jul 2005
    it needs much dismantling before a mechanic can look at it, getting the cover off isnt easy
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    top cover removal is quite simple for a basic inspection if there is any real wear or cracks you would see them with just the top cover off and rotating the engine, a thourogh inspection can only be complete when the belt is removed at which point for $15 dollars you would replace it.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    thank somebody that yo udon't own a WRX, i hear those cambelts take a whole day to do
    Body by Holden, Soul by Brock
    the Legend will live forever
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by immortality View Post
    yep sucks big time, along with those quad cam mitsi's, people say they can tell a cambelts condition by looking at it, I reckon thats a load of c**p, Its like people being able to crack detect blocks with their eyes. if your cambelt is cracked or has any signs of any deformity DO NOT DRIVE YOUR CAR.
    EDIT, a 3L VL would be one of the easiest to do. Skylines with the twin cam motor is easy as too, so SOHC is gonna be easy as.
    VL SL Turbo
    Feb 2006
    100,000kms usally, at work we do them at about 80,000kms to be on the safe side
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Quote Originally Posted by woodyotoad View Post
    it is recommended the rb30 is done at 95,000kms doing it at 80,000 would make it almost 1 year before it is due?? it is ok to go 10,000 over the belt doesn't just break at 95,000kms there is some tolerance.
    Imahoon most mechanics place a sticker under the bonnet (timing cover, inner guard) which tells you when, where and by who it was done. also I wouldn't be to concerned its a toyota they are almost bulletproof!
    on inspecting a timing belt you would be looking for OBVIOUS signs of wear and tear that is why each manufacturer has recommended time to replace because there is wear and tear that you cannot see and eventually it will strip a tooth or snap!
    Toyota Camry?
    Oct 2008
    it only needs half the teeth to still work fine
    P.S. I replaced my timing belt, radiator... and head... lol
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Quote Originally Posted by ImAHoon! View Post
    HAHA your a hoon.
  1. Help with Noise after changing timing belt....
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-12-2008, 01:48 PM
  2. how long is too long to wait?
    By Troy711 in forum The Pub
    Last Post: 03-06-2008, 05:16 PM
  3. Changing Timming Chain/Belt on S1 VN V6 motor
    By deafnu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2006, 06:00 AM
  4. any tips on changing a serpentine belt
    By hildahoop in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2006, 05:52 PM
  5. changing drive belt on VT 5.7
    By xtr041947 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2005, 08:44 PM
