Results 1 to 5 of 5
Thread: help
    vl berlina
    Dec 2008
    Smile help
    hey guys just bought a vl 87 berlina does anyone know how too connect a pioneer head unit usin th old radio wires
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    a quick search can be quite helpful
    anyway heres a post from a while back, good luck
    Quote Originally Posted by VL Berlina 5speed View Post
    i have the deatils hear for all the vl cables on the sound system, ths applys for vk/vls, but i didnt think any commie int eh vk/vl range had rear speakers stock
    accessory +12V - yellow
    Battery +12V- orange
    dimmer in +12V- grey
    ground/earth - black/white
    constant +12v output - pink
    front left speaker +.......- tan
    "_____________" - ........- light blue
    front right speaker +.......- light green
    " _____________" -........- light blue
    rear left speaker +..........- dark brown
    "_____________" -..........- light blue
    rear right speaker +.........- dark blue
    " _____________" -.........- light blue
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    ha ha my vk exec had 1 rear speaker on the passenger side from factory it was hopeless fancy that a 3 speaker system.
    Nobody wants to play with me
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Basically for a CD player to work it just needs 3 things. Power, Earth and Back-up (keeps the CD memory so when the car turns on it will be at the same spot when u stopped). Most times cause im lazy i will just wire up the back-up right to the main power supply and just deal with having to select the song every time i start the car.
    With just these the CD player will turn on and work, then you just wire up the speakers. Now i find it ALOT easier to just send new wires for the new speakers. Follow the instructions on what wire powers what speaker (so u can EQ the speakers) and then just get twitching. I like to remove the back seats (since it takes like 5 mins to remove) so i can hide all of the wires for the rear speakers.
    Basically follow the instructions that comes with the CD player and take ur time. Once u know what is the main power supply and earth (u can even just run ur own earth under the bonnet if u want) with the back-up you can then start playing with the speakers.
    Good luck mate!
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
