hey i own a 1988 vl executive and the battery is draining and i dont know why i charge it fully and in about 3-4 days its dead and i would not have a clue why does anyone have any clue what it might be.
is your boot light stuck on? is the battery fluid low? (distilled water) top it up, or is the battery stuffed? get it tested.
Nobody wants to play with me
Get the battery tested. Could have a bad cell.
Originally Posted by Reaper:
Originally Posted by Jecs:
does your boot have rust in the window channel ?? if so check your boot light switch for water this can cause the boot light to stay on. and also as stated make sure it is a good battery
it has two little dots under the window seal and a bit where the boot seal sits. the battery holds charge its jus wen i connect it to the car but i will check the boot light tomorow.
alternator?
