do i have to change my computer and my air flow meter when i put a stock turbo on my vl rb30... any help would be appriciated
cheers![]()
yeahn computer and injectors. not afm though
This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
you can run a n/a comp and injectors just dont go over 7psi or the injectors will max out soon after that
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
The injectors r different to turbo ones AFM is the same computer is different wiring loom is different in the loom there is one more wire on the turbo models that is the knock sensor this reads pinging
Drive it Don't hide it
thanks for that,
how much psi do u think i can run with fully oversize rebuilt engine bottom to top with crow comp cam, oversize valve springs, 8.5.1 piston tops, t70 turbo, intercooler and oversize injectors? would i be able to run 15 psi or more?
should do mate but youl need to get at least a nistune ecu to run bigger injectors and that much boost.
im running the same gear as you with stock ecu and stock injectors and on 12 psi its fine no pinging or anything
this has been done to death on calais turbo.definatley do not use n/a computer and injectors as it just wont work. standard AFM will support around 200rwk
the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
Where would be the best place to get aftermarket ecu, injectors and afm to support up to 300rwk
cheers thanks for all the help guys![]()
From what ive heard, na injectors and na ecu are fine to run with turbo. Just dont add more boost.
1988 VL Berlina turbo 5 speed
http://forums.justcommodores.com.au/...ml#post1446411
1987 VL SL turbo 5 speed ~STOLEN~
http://forums.justcommodores.com.au/...ed-manual.html
Where can i get a big throttle body for my vl (not XF)
Cheers![]()
xf will be best and cheapest
im not worried about price
and also what compression pistons should i run for 15psi boost?
plazaman trottle body for a vl, think its a few grend though
there a company in vic i think
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
grow some balls? you drive a VR executive!
haha
There's plenty of room for all of God's creatures...right next to the potatos
Mitch's Ex-police VY Commo
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
lol strate over my head to
