Results 1 to 9 of 9
Thread: brake boosters
    '87 VL Calais with L67
    Aug 2007
    Default brake boosters
    hey guys anyone got experience in changing their brake booster for a bigger one?
    would a vt/vy v6/ls part fit the 1" master cylinder?
    what are your suggestions?
    This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    vt boosters need a bit of customizing in the bracket department and you would us the master from the vt
    what about the v8/turbo booster? it bolts up just dont forget to grab the strut tower mounting bracket too as its diff to the normal booster one
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Aug 2007
    Quote Originally Posted by VL Berlina 5speed View Post
    is that the bracket to the strut tower from the master cyl? i dont really mind making one as i can do it at work.
    i just thought that vt etc would be better than vlt or v8. plus easier to get
    Oct 2005
    nah there braket from the back of the booster to the firewall, there was a guide somewhere but where it is i have no idea lol
    as for the strut tower bracket, using a vt im not sure but the v8/turbo one is backwards (bends other way) compaired to the other one
    also i believe you need some line adaptors for the vt master to the metal brake lines,
    the flanges are diffrent
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Aug 2007
    yeah thats why i was keen to keep my vl 1" cyl. might get vp5.0ltr one to match my front discs
    i dont mind a bit of sheet metal work but ive never had to replace a vac booster before. mines not rooted its just a stocko vl6 one and i recon i'd get better brake pedal feel with a bigger one.
    vl berlina wagon 6cyl
    Jul 2005
    the booster for models with drum rear brakes waas too small and not very effective, the booster for all disc models was much better and should bolt straight on
    Aug 2007
    mine is a s2 calais with discs all round. cheers guys for your replies
    Jul 2005
    in that case it may just need to be rekitted by a brake specialist to replace the bits that eventually wear out
    also check air vacuum hose from intake manifold for leaks
    VT
    Apr 2005
    QLD
    Go to the gym and do some leg presses.
  1. V8 and 6 cyl brake boosters
    By mattw in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-09-2008, 05:58 PM
  2. WTB: 6 Inch Speaker Pods/Moulds/Boosters
    By Dirbatua in forum Swap / Wanted to Buy / Trade
    Last Post: 23-09-2007, 11:03 AM
  3. Brake Boosters
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-04-2007, 08:48 PM
  4. brake boosters
    By Calais_5sp in forum General
    Last Post: 05-02-2007, 05:53 PM
  5. V6 & V8 boosters - are they same?
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2006, 09:28 PM
