Results 1 to 8 of 8
Thread: green jack handle
    vl berlina wagon 6cyl
    Jul 2005
    Default green jack handle
    if you still have the original jack, look at the jack handle which on mine was painted green, very easy to lose if changing a flat at the side of the road, I painted mine bright yellow
    many years ago I had a rover and all the tools for changing a flat tyre were bright yellow, to make them less likely to be lost or forgotten about, often we get hot and bothered when having to change a flat at the roadside
    the standard VL jack isnt bad but dont jack up on a sideways slope or the car can lean over, jamming top of jack against car so its stuck and another jack is needed to free it up
    needless to mention, never get partly under if car is only supported by the jack your death may be fast or slow
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Never use a holden Scissor jack.
    /end thread.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    holden scissor jacks are good, when you use the old one post side jack they had in early commies you will think a scissor jack is good ha
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Ive had the Holden jacks strip the thread and just fall. Luckily the car wasnt high enough and i still had the wheels on.
    Get a trolley jack for the shed and a smaller trolley jack for the boot. Just so u can change a tire cause those Holden ones can be dangerous.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by Paiste402 View Post
    Your talking about the early jacks I guess? The scissor jacks are tough as. I've had huge weight on them before no problems. They just take alot of power to wind up with some weight on them, that's the only problem
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    when used CORRECTLY the jacks are effective for emergency tyre changing not really recommended for much else though and they must be on a flat level surface.
    Nobody wants to play with me
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by greenfoam View Post
    As soon as i buy a car, the first thing i do is throw the scissor jack in the bin. If i knew you liked them so much i would've sold them to you haha
    cheers sexy
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    My jack is currently painted rust.
    Had the car fall off the suicide jack once. The jack collapsed and the car smacked into the bin...made a dent in the panel, luckily i wasnt under it at the time.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  1. where do i jack up?
    By Marky4101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2008, 12:44 AM
  2. AUX jack on the ss
    By Prodrive in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-05-2008, 07:11 PM
  3. how to jack it?
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2008, 10:55 AM
  4. how to jack up a VL
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-08-2007, 10:46 PM
  5. WTB: VT-VY Jack Handle/Wheel Wrench
    By Camotec in forum Swap / Wanted to Buy / Trade
    Last Post: 27-09-2005, 09:57 PM
